Question about Westinghouse Televison & Video
Pavy remote code for Westinghouse tv - Westinghouse Televison & Video
Posted by paper Chzn on
    Top Expert:
  • Westinghouse Master
  • 76,416 Answers
0392,0330,0318.0217.0229. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" of your device; that you want set-up code, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jan 25, 2017
5 Related Answers
Anonymous
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Posted on May 08, 2009
pabloloco
Paul Sager
  • 2335 Answers
SOURCE: codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Posted on Oct 16, 2009
danbusa
Daniel Busa
  • 185 Answers
SOURCE: Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Posted on Apr 19, 2011
Testimonial: "Thanks for the tip on the Power scan. I was trying the power scan described on some other webpage and it didn't seem to work. Your tip was dead on "
BeckiB_DISH
Becki Barned
  • 286 Answers
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Posted on Apr 21, 2011
roosterjj197
SOURCE: I am using a PAVY
If you press the setup button until the red light stays on then press the channel up button until it changes the tv station then press enter
Posted on Nov 23, 2011
Need codes to program a Sony TV from a pavy universal remote
Use code search in your Pavy URC to find something that works. If no results, you may have to try a different URC. All URCs do not contain all possible codes.
May 20, 2018 | Sony Televison & Video
I NEED A CODE FOR TV CONTROL REMOTE (PAVY) TO SET TOSHIBA TV.
The code will be in the Pavy remote control, if it is compatible.
May 14, 2018 | Toshiba Televison & Video
Pavy universal remote codes for lg tv
Robert, Not much to be found on this remote. Codes for a Pavy Universal Remote for an LG TV are 002,102,307,324,435,502,606,609,619,700,802 and 910. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What are the codes for an LG TV with Pavy remote
Pavy 330015 Instruction Manual
Aug 20, 2016 | LG Televison & Video
What is the three digit code for a Pavy Universal Remote?
You can use the code search feature of your Pavy universal remote to find something that will handle some or all Vizio functions. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
May 03, 2016 | Vizio Televison & Video
What is the code to a Phillips tv with a pavy universal remote?
Codes are stored in the remote. You can use its code search feature to find one that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Mar 21, 2015 | Universal Televison & Video
I have a Pavy universal remote I'm trying to program to a Sanyo television
Your Pavy universal remote probably has a code search feature you can use to seek a suitable code. If a search through all codes stored in the remote is unsuccessful, you may have to try another universal remote.
Feb 07, 2015 | Sanyo Televison & Video
How do I program a pavy universal remote to a RCA tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily.
Sep 28, 2014 | Televison & Video
Pavy universal codes for a durabrand
please go to www.fitness.manualsonline.com or www. remotecodelist.com
God bless you
Jul 01, 2012 | Universal Remote Control Televison & Video
I NEED LIST OF CODES FOR UNIVERSAL REMOTE BRAND PAVY PLEASE TANKS
List of codes for universal remote brand pavy for Panasonic tv
Jan 01, 2011 | Televison & Video
Televison & Video Logo
112 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
