Question about Kitchen Selectives Coffee Makers & Espresso Machines
Kitchen Selectives Cm-3423 5 cup drip coffee maker won't brew. The light to signal power comes on, but nothing happens. Any ideas as fsr as what the cause may be? Thanks!
Posted by Nick on
1 Related Answer
Anonymous
SOURCE: Need Replacement pot for black Kit. Select. Dual Pot Coffee Maker CM-202
Select Brands
Kitchen Selectives
Select Brands
Customer Service Or Call 913-663-4500
To order replacement carafes for the CM-202 Dual Coffee Maker you have to call Customer Service at 913-663-4500 - This item cannot be ordered on line.
Posted on Jan 01, 2009
I'm looking for the coffee pot only for kitchen selectives cm-312-p, where could I buy one?
Select Brands, the maker of Kitchen Selectives, doesn't list your model. This might mean it's no longer in production or was a custom model for a retail outlet. This page at their site gives contact information. All I can suggest is that you contact them and see if they can tell you where you can find an original replacement, or see if one of the universal replacement carafes at retail stores might be a close enough. Good luck, and thanks for using Fixya!
Dec 15, 2010 | Kitchen Selectives CM-202 Coffee Maker
KeurigB50 Coffee Maker will not brew. Gets to the
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
I have been looking for a Kitchen Selective 12-Cup Dual Coffeemaker, CM-202 for months. Walmart has one for under $38.00 but it is always out of stock. Therefore it is hard for me to see myself paying $60+...
http://www.thefind.com/appliances/browse-kitchen-selectives-dual-coffee-maker
salestores.com/selectbr.html
http://www0.shopping.com/xPO-Kitchen-Selectives-CM-202
http://www.priceground.com/cm202.html
Oct 28, 2009 | Kitchen Selectives CM-202 Coffee Maker
Need replacement lid for coffee pot
I called Select Brands at 913-663-4500 to order the replacement caraffe for this coffee maker. Their email is [email protected] The website is under construction so orders cannot be placed online. I broke my coffee maker yesterday and still have my lid - guess I'd better keep the lid....
Feb 04, 2009 | Kitchen Selectives CM-202 Coffee Maker
Basket to kitchen selectives dual coffee maker lost
Call customer service at 913-663-4500. They were very helpful for me.
Good Luck
Dec 29, 2008 | Kitchen Selectives CM-202 Coffee Maker
Select Brands
Kitchen Selectives
Select Brands
Sep 10, 2008 | Kitchen Selectives Coffee Makers &...
Coffee Makers & Espresso Machines Logo
219 people viewed this question
Top Kitchen Selectives Coffee Makers & Espresso Machines Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Terry
Terry
Are you a Kitchen Selectives Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
