Question about Connex Radio Communications
Lower dead key on connex 3300 - Connex Radio Communications
Posted by Otto Zavada on
5 Related Answers
Gavin93
EDACS
  • 66 Answers
SOURCE: connex 3300 c.b radio
The Connex radio is a division of Cobra, and no offense, but Cobras are one of the cheapest radios around. The problem with your Connex is a simple receiver malfunction. The receiver probably worked great until it was put into storage for a long time, you can replace the receiver, or you can fiddle around with the receive gain until you hear something. But you may just want to send it to a radio store and have it looked at, to be honest with you, Connex is a terrible radio, they sound good, but they're terrible radios. Go with Galaxy or Uniden radios, you won't be disappointed.
Posted on Jul 02, 2008
One Wire
Dean Pitts
  • 126 Answers
SOURCE: Manual for Connex 3300 HP
The best place for anything related to cb radios and ham radios is www.cbtricks.com.
Here is a direct link to the owner's manual for a Connex 3300hp
http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Dean Pitts
Rollin CBs
Posted on Aug 31, 2008
Melanie Rogers
  • 219 Answers
SOURCE: would like to peck recive on connex 3300 moble
adjusting the receive is something you don't want to touch unless you know a radio.....and for the rci2990 without looking at it I'd say you have a bad soilder on the voltage regulaor or the voltage reg, died.
Posted on Jan 16, 2010
JOHN BABA
  • 1274 Answers
SOURCE: Knob setting of front of radio (Connex 3300)
The best way to set it is to get you a radio check, go to channel 19 and ask someone about three to five miles away to give you a radio check, start with your modulation all the way open and go from there.....hope this was helpful...
Posted on Apr 20, 2010
Melanie Rogers
  • 219 Answers
SOURCE: my radio i can key up the light changes but
First off you can by any radio parts that you need and any good CB shop knows that.But if its only a little over a year old then you can send it back to factory and it'll be fixed free. There is a serial number on the back of the radio the first to digits is the year and the second two the month it was made so is a year or a little over a year old if so call 1-814-898-1046.
Posted on Jul 14, 2010
Connex 3300 HP ,tx light on,dead keys 45 - 50 watts ,no modulation
Check for a Bad, whats called the AM regulator on the back corner of chassis by pwr connector. 2sa or 2sb styles. 2sb817 if available is a good $3 replacement.
Nov 04, 2015 | Connex Radio Communications
What watt dead key and swing on CONNEX 3300 HP
A standard 3300 hp I seen get up to 40 watts peak,
normally I would turn the audio pot up all the way never snip anything and deadkey down to 2 watts. Than adjust for forward swing, I also never run a pwr mic. Good luck
Apr 20, 2015 | Connex Radio Communications
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
Would like to peck recive on connex 3300 moble
Jan 15, 2010 | Connex 3300 240-Channels Base CB Radio
Does anyone know the pod too turn for lowering the watts on my connex it is too high and i would like to turn it back also the modulation thanks
You have to adjust the high key first so make sure you're rf power is on high, hope you have a meter set it on the 20 watt scale, key up and turn vr 13
located in back of radio infront of where you're coax connector is until it keys around 12 watts, thats where most connex 33hp should be set,now go to low power and key adjust vr 16 right net to the otherone down to about 3 watts, now you can drive a liners. Mod is Vr 2 right below them two. whistle in mic and turn to get the mod you want.
Jul 15, 2009 | Connex 3300 240-Channels Base CB Radio
Connex 3300 c.b radio
Jun 30, 2008 | Connex 3300 240-Channels Base CB Radio
Switching radio bands
what radio do you have? does it even have sideband channels? some radios don't come with them, of fm or upper or lower side bands and short wave
Dec 08, 2007 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
141 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
