Fuses are located in the relay center, on the passenger's side, below the instrument panel. You must remove the sound insulator on the right side of the passenger footwell to replace these fuses. Open this and you will see a bunch of relays and in the lower left hand corner is 4 rows of 3 fuses. The 3rd one down on the left hand side is the horn.
SOURCE: 1999 Oldsmobile Cutlass Cigarette Lighter Fuse
Under the hood directly in front of the driver is a covered fuse block. Remove the cover and the fuse is #34.
SOURCE: 1994 oldsmobile cutlass supreme sl the fuse box for signal lights
the fuse box will be in 1 of 3 places (1)glovebox (2)under dash by drivers foot kick panel or (3) under hood .
SOURCE: 1999 Oldsmobile cutlass horn sound by itself. What
The horn pad has shrunk dued to the climate change through the years. The pad is made of vinyl and does retract causing this to happen. The best way to repair this since new ones are most likely discontinued is to find a used one from a state such as Arizona California were the climate is steady year round
You will have better luck with this replacement for many years to come
SOURCE: how to replace a blower motor on a 99 oldsmobile
remove lower right dash insulator panal from beneath glove box. slide bcm aside to get to blower. remove the three screws holding the blower motor, pull blower and fan straight out. remove fan from old blower if replacing with a new motor. good-luck!!
