Question about Jensen Audio Players & Recorders
I have purchased a JENSEN Bluetooth Music System with CD player
I can not get it to play. I put in the 6 batteries, they had been used for 2 weeks in another player. The light comes on but when the Cd is placed, it does not.move. The play indicator light comes on but the CD DOES NOT move. Even though the CD IS IN, the word "no" is on the screen. Please HELP!
Posted by Mary Page-clay on
5 Related Answers
Anonymous
  • 30 Answers
SOURCE: eer 2 message on bose 6 cd player on 2001 pathfinder
you may need bose qualified serviceman to erase the error,you may need a software from bose.
Posted on Jan 27, 2007
Anonymous
SOURCE: won't play a cd
put a mp3 cd it will work worked for mine has truoble reading regualr cds
Posted on Feb 08, 2008
ansari_farid
  • 46 Answers
SOURCE: Disc error when reading dvd
If cleaning of the lens did not help then it is possible that the laser beam torch needs a replacement. Different formats need different strengths of the beam and the torch would need to be replaced.
Posted on Jan 15, 2009
Anonymous
SOURCE: CD player acknowledge CD, starts to play, then stops
replace belt in lazar assembly and clean lazar eye with quetip with rubbing alchol
Posted on Oct 07, 2009
Kyle Hinton
  • 3 Answers
SOURCE: CD PLAYER FORD EXPLORER
I have an '03 Explorer with the 6 disc changer. It does the same thing. Many times, you can set the radio to "FM1" and hold down buttons 3 and 6 on the radio. This will put the unit into self diagnostic mode. After it runs the diag., turn off the ignition and remove the key for at least 30 seconds. Sometimes it takes a couple times but it always works on mine.
Posted on Feb 08, 2010
1helpful
2answers
Can't get headphones to work on this unit
Aux-in jack is used to play another device such as an Ipod or other sources through your Jensen player, using it as some sort of an amplifier. Look for another port on your Jensen player that says "audio out" or "Spkr" (means speakers) to plug in her headphones. If you can't find any of these ports then you might have purchased a n actual boom box, which does not have the capability to play through headphones, sorry about that.
How do i download music on my jensen mp3 player
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
1helpful
BOSE WAVE MUSIC SYSTEM PLAYS CD BUT DOES NOT TURN OFF
It is probable that the battery will need to be changed, this the first step to find out if additional work is required.
2helpful
2answers
Jensen Personal CD Player Model CD-60 won't play cds. It starts and then shows "ER " message. I've put in fresh batteries - no change. Appreciate your help, thanks so much!
Have you try a Cleaning Disk. Maybe you can use a compress air can (usually sell in pc/electronics stores) and clening up the laser lens. Check for dirty on discs, water drops or scratches. Try another CD
Hope this help.
Regards,
Jensen mp3 smp 2 GBL
Try using updating the firmware from manufacturer's website.
2helpful
My jenson mp3 model smp-2gbl wont stay on
i have a jensen model# smp 2 GBL it wont play it comes on for a second then turns off. I took out the music put in new music then it played for 5 minutes then turned off and does the same thing again. I put in alot of new batteries that dont work either can you help me
Music cds
someone told me that the intire system was just going out and that there is no way to fix it you have to get a new one
Jensen car stereo
just turn the changer on, make sure it is playing a disk, (and you know whats playing) the press the scan function on your radio til it picks up that signal and lock it in.
Jensen VM9510 No voices in movies
It sounds as though the unit is set up for "6-channel" surround mode, but you don't have a center speaker. That means the audio sent to that speaker isn't being heard. You'll need to get to the audio setup menu, and either turn off the 6-channel mode, or turn off the center channel option. There are two different Jensen models with the VM9510 model number, but you can download an owner's manual for either one here: http://www.audiovox.com/webapp/wcs/stores/servlet/GenProductListCmd?type=model&catalogId=10001&storeId=10001&categoryId=VM9510&langId=-1&page=&urlString=&productId=&brand=
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
