Question about Measuring Tools & Sensors
Changed batteries and now cannot get an outdoor reading.how do I fix this?
Posted by Pauline Beaumont on
Tom Chichester
    Top Expert:
  • Measuring To... Master
  • 57,296 Answers
  • Remove all batteries
  • Install batteries in outdoor unit
  • Make your way indoors at a leisurely pace. This allows the outdoor unit to initialize and begin sending data
  • Install batteries in indoor unit. You should see outdoor temperature displayed
In cold weather, the outdoor temperature display may disappear due to frozen batteries. At the moment my reading is - - because it is around 40 deg. F. However, in a day or two when the outdoor temperature reaches 50 deg., the outdoor temperature will be displayed again. All in all, rather whimsical.
Posted on Jan 23, 2017
Radio Shack outdoor thermometer remote sensor 63-1026 reads LL.L Replacing batteries and reset didnt help. How to fix?
  • Install new batteries in outdoor unit and allow time for it to begin sending data
  • Install new batteries in indoor unit. You should see outdoor temperature displayed
Jun 24, 2018 | Miscellaneous
Ambient weather, model WS-2801...our outdoor readings have quit recording after changing the batteries.
  • Install outdoor unit batteries. Wait for outdoor unit to initialize and begin sending data
  • Install indoor unit batteries. You should see outdoor temp displayed. If not, the outdoor unit may have failed
May 14, 2018 | Measuring Tools & Sensors
Why isn't outdoor temperature displayed?
Try repeating the initial set up procedure. Remove all batteries from outdoor and indoor units. Install known-good batteries in the outdoor unit. Allow time for the outdoor unit to begin transmitting data. Install known-good batteries in the indoor unit. You should see the outdoor temperature displayed.
Feb 09, 2016 | AcuRite Acu-Rite 00621 Wireless Weather...
Can't get a temperature reading on my Springfield 91756 thermometer even after changing batteries. Just get - - -.
The batteries in the outdoor unit have to be changed first and time allowed for it to begin transmitting. If you are in a very cold location, the batteries may may decline in efficiency to a point where the outdoor unit can't transmit. In this case, you may find that the temperature reading returns in warmer weather.
Feb 23, 2015 | Springfield 91751 Digital Rf Weather...
Why does my outdoor temperature show a constant 35F?
It might not be in range I wouls try bringing them closer together or bring your outdoor sensors inside untill yoh get a reading
Dec 21, 2014 | Measuring Tools & Sensors
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
I changed batteriers and now I can't get a reading from the remote. I have hit the reset on both units. Maybe not in the righ order.
I believe they ask you to press the reset button on the main unit first, but that may not be your problem. Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. Also, make sure the units are close enough to transmit.
Sep 26, 2010 | Oregon Scientific RMR382ABLACK Wireless...
Can't reset Taylor 5367 indoor/outdoor thermom
I changed the batteries on mine and it reset itself. That was easy.
Dec 09, 2009 | Kitchen Appliances - Others
Measuring Tools & Sensors Logo
703 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
