Question about Yes Televison & Video
Yes i am trying to watch tv cable, was working yesterday and now cant input tv from source
On the screen it says no channel is registered
Posted by KEVIN SANDERSON on
5 Related Answers
Telecom
SOURCE: tv not working
Can you confirm that you didn't have any input signal? My wife once accidentally pressed the reset button on the remote and the TV was stuck in this state. I tried to hook up an antenna to the digital antenna input and let the TV search for a channel. It did find a station and got out of the channel search mode, which was all I needed. Then, I unhook the antenna and continued to enjoy my DVD movie. I didn't check the manual. So, it's possible that there is a better solution. My TV was working fine and I think it just has a terrible user interface. I'm not sure about your TV's condition, though.
Posted on Sep 19, 2007
Anonymous
  • 208 Answers
SOURCE: HDTV Sharp- Input select to watch Cable tv
On the sharp remote you will find an input button. You depress the input button and a menu will appear and highlight the input you are presently on. Hit the input button again to select the next input. If you wait to long to depress the input button it will not work and you have to begin again. This unit will only hightlight inputs have a component hooked to that input.
Posted on Feb 05, 2008
Anonymous
  • 30 Answers
SOURCE: DS24205 TV INPUT PROBLEM
You can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Posted on Oct 17, 2008
salsaurbana
Luis Rondon
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: change input source for philips magnavox
use the up/down channel until you get to the input you have connected. You did not say you had a remote so i am using the standard fix for this.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 28, 2009
I need help to register to channel 9 I wake up with today
you make it happen by calling the phone number on the screen when advertised
May 16, 2017 | Televison & Video
How do I link amazon music channel with my amazon music account I cant enter the code anywhere.
Sounds like you are doing it backwards. The registration code appears on your TV screen when you add the Amazon music channel to your channel list.
Go to Roku main screen
Choose "channel store"
Choose "music"
Choose "Amazonmusic"
choose 'go to channel"
Code will appear on your screen. Enter it on your computer at the rokumusic address you used in your post.
That should get the tunes flowing!
Dec 11, 2014 | Roku HD Streaming Player
Can't locate channel
You're going to have to call their customer support and have a chat with them, they most likely will send someone out and charge you for that though if they can't fix it remotely from there call center.
Feb 25, 2013 | directv.com
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
My TV will not register channels
Think that your tuner section has been compromised by the surge. Happens. If your other audio/video inputs work you can plug an external tuner in there.
Aug 22, 2017 | Emerson Televison & Video
My little brother and friend want to play wii mario kart wii together. They are in the nintendo WFC and have both connected, but can't figure out how to actually PLAY a game, help?
You need to install the Mario Kart Channel.
When you are in the Mario Kart Wii game, go to the "Select License" screen.
Click on the "Settings" icon in the top right corner.
Select "Mario Kart Channel.
"yes"
"Install."
your friend will need to tell you their 12 digit friend code. They can find it by going to the Mario Kart Wii Channel Select License screen.
Chose their profile.
Select "Friends".
Their 12-digit friend code will be displayed near the bottom of the scree
from the Mario Kart Wii Channel Select License screen, chose your player profile.
Select Nintendo WFC - either 1 or 2 player.
Select "Friends"
Select "Register a Friend."
Enter your friend's 12 digit code, then select "OK" to confirm.
If you found this info useful please vote for me
Mar 11, 2011 | Nintendo Mario Kart (Wii) for Wii
My father in law has one of these digital recievers and on channel scans it says no channals! im unfamiliar with these recievers and i was wondering if u need to register or need a special antenna or what...
where was the receiver bought from? The receiver needs to be registered before it can get channels. Also you need the help of an expert that will help you scan the channels using the right/correct frequency.
The receiver needs to be connected to a dish, subscribed (registered), and it should get channels.
Good luck.
Nov 24, 2010 | Televison & Video
Channels will not program in tv.check with different tv it works
when turning on the tv I get a screen states no channel is registered. and press hold enter key on the remote control for 3 seconds.. one problem is I dont have a remote to the tv only an ge unversal remote which can the get programed
Mar 13, 2010 | Sylvania LC195SLX LCD TV
Televison & Video Logo
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
