Question about Ricoh Aficio Office Equipment & Supplies
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
SOURCE: scanrouter v2 lite at ricoh aficio MP 4000
you dont need scanrouter for mp 4000
Posted on Mar 21, 2010
SOURCE: I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
Posted on Aug 12, 2010
SOURCE: how can i solve error code sc:302 in ricoh Aficio
You should have a service technician take a look at your copier. SC302 is a charge roller current error, and it could be caused by a number of things, from a dirty charge roller to a faulty high voltage supply board.
In the meantime, try turning the machine off, unplugging it, and then plugging it back in and turning it on the see if the error message will clear.
Posted on Aug 26, 2010
Sep 25, 2014 | Ricoh Office Equipment & Supplies
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
Nov 15, 2010 | Ricoh Aficio 1035 Copier
Sep 27, 2010 | Ricoh Aficio MP1600SPF Copier
Sep 06, 2010 | Ricoh Aficio MP 1600 Black and White...
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Aug 24, 2010 | Ricoh Aficio MP 2000 Black and White...
Apr 29, 2010 | Ricoh Aficio MP 2000 Black and White...
Sep 30, 2008 | Ricoh Aficio 1013F Copier
141 people viewed this question
