Vacuums Logo
Tammy Vandiver Posted on Jan 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Was using my cleaner it went off and now it won't turn back on
Thatvacguy.com
Level 3:
  • Vacuums Master 1,619 Answers
  • Posted on Jan 22, 2017
Thatvacguy.com
Vacuums Master
Level 3:
Answers
1619
Questions
0
Helped
604838
Points
3345
Many models have a thermal reset to turn off the vacuum if it gets hot. Better vacuums have a mechanical reset switch that you push to reset. Most vacuums have an automatic thermal cutoff built into the motor, if it gets too hot it shuts off the power and will reset itself when it cools back down. If it shut off due to getting too hot it indicates a clog somewhere or the filters are clogged or the bag is full.
How do i fix dyson DC41 Animal vacuum upright cleaner it has burning smell coming from motor and it blew the fuse box when i WENT TO VACUUM. the wire flex is a bit over twisted
You most certainly shorted this out and will need a new cord. Easy fix but you will have to take it apart and find where it failed. I doubt the motor fried but it is possible. When you take it apart look for the burn mark left by the electrical arc. That is the point you fix.
2answers
Kirby Vacuum Cleaner on/off switch won't stay switched on
If the motor turns on turns off in the course of the vacuuming, check the cord or the switch This is how you replace your cord on a Sentria vaxuum.
1helpful
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 • Vacuums
2answers
The vacuum won't start. I used it for about an hour and then turned it off and when I went to turn it back on ..there was no response. I cleaned every compartment on the machine and it's still not...
Sorry to hear you're having difficulties with you're DC07. If the cleaner won't run at all, it's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to [email protected], someone will be in touch with you as soon as possible. We look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
2answers
My vacuum was working fine just a minute ago, and i turned it off to finish laundry, and now when i go to use it again, the handle won't recline... is there something stuck??
Sorry to hear you're having problems with your DC17. The cleaner should recline easily into the vacuuming position when you place one foot on the cleaner head, and tilt the handle back. If it's not doing this, please get in touch with us free on 1866MYDYSON, or email [email protected]. One of our experts will be happy to provide further assistance.
Kind regards,
Jack
2answers
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761326
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
