Its speed regulator electronic circuit inside is faulty. There is a control circuit to determine the time and speed of the blender. It will contain a pre-programmed IC. This board is nor a repairable one. It should be replaced as card basis. Its one touch pulse only energises. No other speed regulation section does not works, and the IC related to this is faulty. Normaly pre-programmed; otherwise known as {PIC} ICs are programmed by the manufacturing company, and will be difficult to get from outside electronic spare-part market. So you have to contact the Breville service center to get this device repaired.
SOURCE: Any idea where we can get a new jug for a breville blender?
This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
http://www.brevilleusa.com/home.do
SOURCE: blender will not run. the power button is lite but
There is a 10 Amp thermal fuse (SF129E) that is supposed to create an open circuit when the motor windings exceed 133 C degrees. Although this fuse should close again when the motor cools down it can become perminantly damaged. Locate the fuse by following the black leads from the coltrol board to the motor brushes. It's inside a cloth insulating sheath secured against the windings with a metal strap and two ty-raps. I bypassed the fuse with a wire instead of replacing it. It would probably just blow again sooner or later. p.s. you need a T10 Torx screw driver to disassemble (screws under rubber feet) $3 at ACE hardware.
SOURCE: Breville Blender BBL600/A. Only pulse touch button
Hello
Its speed regulator electronic circuit inside is faulty. There is a control circut ot determine the time and speed of the blender. It will contain a pre-programmed IC. This board is nor a repairable one. It should be repaced as card basis. Its one touch pulse only energezes. No other speed retulation section does not works, and the IC related to this is faulty. Normaly pre-programmed; otherwise known as {PIC} ICs are programmed by the manufacturing company, and will be difficult to get from outside electronci sparepart market. So you have to contact the Breville service center to get this device repaired. OK.
check the fuse
