There is a TSB available if you're under 60,000 miles take it the dealer.
light occurs when:The center airbag sensor assembly receives an open circuit signal in the side squib (front passenger side) circuit for 2 seconds.
possible trouble areas include:Front seat airbag assembly RH (side squib (front passenger side)), Center airbag sensor assembly, & No. 2 floor wire.
SOURCE: 2006 scion tc
should be a shift lock button towards the top of the gear lever? if not then just use a jump battery.
if you can't get to the cars battery buy a cheap plug for a cig lighter socket and and use a 12v battery. a 9v battery may do it if your fast.
SOURCE: How do I reset the check engine light for a 2006 scion tc?
YOU CAN GO TO ANY ADVANDED AUTO PARTS AND THEY CAN HOOK UP A OBD2 SCANNER, WE THEY DO ASK THEM TO RESET THE LIGHT FOR YOU.. THIS IS A FREE SERVICE TO THE PUBLIC..GOOD LUCK KEITH..
SOURCE: Can a 2006 Scion Tc cd player fit into a 2005 Scion Tc?
yes its the same plugs but you wont have the steering weal control
SOURCE: how much oil does a 2006 scion tc 2.4 engine take
changing oil on Scion tc is actually 5000 mile in which your service engine light will come up and the oil actually 4 1/2 liters to be exact. i will 5/30 on yours
SOURCE: tire presure light stays on psi is 32 all tires
Hello! You're problem could likely be a problem with the TPMS, or (Tire Pressure Monitoring System) - sensor. There is one in each wheel, and it's recommended that with any tire changes that they be rebuilt or replaced. I'm not sure if you've reset the tire pressure switch or not, but if you haven't and aren't familiar, the button is located inside the glove box. With the car on, press the button for 3-5 seconds and release. Turn the car off, and then back on and your light should be off.
Hope this helps and good luck! Thanks for using FixYa!
