Question about Spectroniq Televison & Video
Spectroniq pdv 808 power light on screen flashes spectron logo screen goes blank power light still on
5 Related Answers
Anonymous
  • 324 Answers
SOURCE: IBM T40 Screen goes off after few seconds
survival,
Here's a couple of things to try:
Power down and remove the battery. Leave it out until you are done with the following procedures. Remove the memory modules and put only one back in. Try to power up. If that works, replace the other one and power up. If that works, you're fixed!
If not, try to power up in safe mode and see what happens. If it comes up, try running diagnostics on the HDD. If that fails, try reseating the hard drive.
Let me know how you're coming along on this. May be able to come up with more ideas, if needed.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Posted on Nov 26, 2007
Anonymous
SOURCE: Screen powers up then goes blank after 2 seconds
Hi, was there a resolution to this? I am experiencing the same problem with LCT3285TA purchased at Radio Shack in Media, PA. Radio Shack has refused to service the unit and has put me over to Akai for the manufacturer's warranty. I'd like to know what to expect and if this problem with the Logo coming up and the unit shutting off/restarting can be easily fixed, thanks.
Posted on Jan 29, 2008
Anonymous
SOURCE: i have a spectroniq pdv-700
well just called them, they are NO LONGER IN BIZ
A message says they filed for bancruptcy on June 16th 2008
GLAD TO SEE THEM TAKE A HIT , BUYER BEWARE!! THEY CAN OPEN UP UNDER ANOTHER NAME TO CONTINUE TO SELL BAD PRODUCTS!
Posted on Sep 22, 2008
Anonymous
SOURCE: at power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
Posted on Mar 01, 2009
Anonymous
  • 458 Answers
SOURCE: SCREEN WENT BLANK, POWER ON INDICATOR LIGHT
SU OR SU BOARD BAD NEED REPLACED
TH-42PX75U PART:
Manufacturer Panasonic Part Number TXNSD1HNTU Description SD BOARD
Manufacturer Panasonic Part Number TXNSU1HNTU Description SU BOARD
Posted on Sep 17, 2009
Where can i buy charger and ac adapter or battery charger for Spectroniq PDV-70x
Power adapters for most electronic devices can usually be readily found on EBay for a reasonable price.
Here is a direct link to an AC power adapter for that model currently available for around $16 US:
http://www.ebay.com/itm/12V-AC-power-adapter-Spectroniq-PDV-70X-DVD-player-/250823360167?pt=Laptop_Batteries&hash=item3a663cbea7
And here is a link to a 12V Car power adapter for that model as well currently available for around $13 US:
http://www.ebay.com/itm/Car-Adapter-Power-Cord-4-Spectroniq-PDV-70X-DVD-Player-/110734902621?pt=LH_DefaultDomain_0&hash=item19c850855d
Just use your mouse to click on the links, which are the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Just search for the term: PDV-70x in the EBay search box and you will see many items available for various prices. Just find the one you want at the best price, order it online, and have it delivered right to you. Just be sure to consider and include the different shipping charges to your location which are listed just below the asking price of the items.
I hope this was helpful.
Good luck and take care.
Joe.
Nov 28, 2011 | Spectroniq PDV-70X
Tengo problemas con el dvd no lee ningun disco
Hay un poco de problema con ese marca de fabrica.
Uno: el producto es de canada y fue hecho en 2006. Tonse el Firmware Necesita ser puesto al d?a.
Dos: El producto lla no lo asen tonse no vas a poder ponerlo al dia el firmware de tu dvd.
Los dvd de hoy usan diferente codigos tonse tu spectroniq no tiene los codigos de aqui pare que lee el dvd. Solo puede lee viejo dvd que conprates.
No hay nada que aser con tu producto.
Mar 09, 2011 | Spectroniq PDV-808
Sound and manufacturers logo show on tv screen when powered up however no picture.
The inverter may have gone out. If the display is momentary such as for the logo, the inverter cannot hold the high voltage to sustain for the back-light. Shine a flash light on the screen and see if you can detect any images. If you can, then the back-light inverter is bad.
Nov 08, 2010 | Spectroniq PLTV-42HW68 42 in. LCD TV
I have a 42 inch spectroniq tv, i moved over the weekend, so i unplugged the tv and when i plugged it up at my new house, i just get the sound with a blank screen
I have a Spectronic LCD HD 42 "color screen is black with bright colors, sometimes does not look good, it lacks definition to see.
Oct 30, 2009 | Spectroniq PLTV-42HW68 42 in. LCD TV
I NEED A BATTERY FOR MY PORTABLE DVD PLAYER MADE BY SPECTRONIQ
You will have to purchase a replacement battery from the manufacture or their authorized parts distributor. Don't waste time looking in electronics stores, because you won't find it there.
Jul 04, 2009 | Spectroniq PDV-808
Broken disk lid
Not sure if you can find a replacement lid but you may be able to play DVD's if you manually depress the small switch that the lid would engage if it were closed. The switch is located where the lid hinges at the right side, you should see a small rectangular hole. The switch can be depressed through that hole. Of cousre, your DVD will be spinning with no lid to protect it but just don't touch it while the disc is playing. When done playing, you can just turn the unit off or remove whatever you used to engage the small lid switch.
Greg
Nov 06, 2008 | Spectroniq PDV-808
Spectroniq PDV-768
uk dvds are formatted in PAL
us dvds are NTSC
find your settings screen (usually has a wrench to identify it)
Nov 02, 2008 | Spectroniq Protron 7'' TFT LCD Portable...
PDV-808 Disc Not Spinning
can you see on the optical lens if the lights goes on.. if the red lights on.., problem is int he flex cable/cable wire/ or what so ever term use by the manufacturer.. posible also defective optical lens. or try to re adjust the trimmer on thier circuit.. tnx
if problem persist desame you may contact to the qualified technician.
Dec 30, 2007 | Spectroniq PDV-808
Televison & Video Logo
Top Spectroniq Televison & Video Experts
Charles Tidwell
Al Ursich
Level 1 Expert
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
