Question about HP Office Equipment & Supplies
How you resolve your paper jam issues in your HP Printer?
Posted by adam smith on
Annie Ross
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
During the print command, the printer is stop printing the pages, and a HP printer paper jam error message show. That means paper might be jammed inside the printer.
Paper jams can occur in multiple areas of the printer.
·Turn off the printer, and then unplug the cable from the outlet.
·Turn the dial on the rear access door counter-clockwise, and then pull the door toward you.
·Clean the printer roller from wipe with a wet cloth
·And then wait for 10 minutes.
·After that remove jammed paper that is accessible from the rear access door.
·If you cannot possible jammed paper from the rear access door then carefully remove in the front.
·If you any damaged paper then removed and re-stack and reload the paper again.
·Reinstall the rear access door.
·And the printers reconnect the power outlet and then turn on.
·Try to print.
.Use full link:- https://printeroffline.support/hp-printer-paper-jam
Posted on Aug 22, 2019
macykaelyn
    Habit-Forming:
    Scholar:
  • 48 Answers
Here is a solution for paper jam issues in your HP printer. There are eight solutions to solve this problem.
    ·Turn the printer off and then on again.
    ·Clear the jam from the rear of the printer.
    ·Clear the paper jam from the paper trays.
    ·Remove the paper jam from the carriage path.
    ·Clean the rollers.
    ·Clear the paper jam from the automatic document feeder.
    ·Perform a power reset.
    ·Service the printer.
    To Turn the printer off and then on again:
    ·First you have to Press the Power button off.
    ·And then wait for 60 seconds.
    ·Again to press the power button on the printer.
    ·Load Letter or A4, unused, plain white paper into the printer input tray.
    ·On the printer control panel, to touch the Right Arrow to display the second navigation screen.
    ·Now select the Setup icon.
    ·Select the Down Arrow to click the Reports.
    ·Now touch the Printer Status Report. The self-test report prints.
    If you have any issues to resolve your paper jam issues in your HP Printer call this toll free number +1-800-836-3987 or visit our blog oj6830.
Posted on Jul 31, 2017
How to open rear access door
1, To clear the paper jam issue at the rear of the printer, perform the printer reset to resolve the issue in a simple way.
2, To reset the printer, remove the papers from the input tray while the printer is turned on. Unplug your printer's power cord from the rear of the printer.
3, Now open the cartridge access door and check if the carriage can move freely along the paper width guide. Look for the jammed paper and gently pull it out. If some paper bits are found inside the printer parts, try to remove them too.
4, You can now print a test page by pressing and holding the Cancel button along with the Resume button. The printer would have got reset, and the test print would have resulted well.
5, Even after resetting if the paper jam issue did not get resolved, better service the printer in the nearest HP retail stores.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
Aug 07, 2014 | HP LaserJet M1005 Printer
Why HP c4480 showes paper jam error but no paper jam and not printing
Please access the steps that should resolve by clicking on the link Paper Jam Message Displays on the All in One
If issue still persists please contact HP for further assistance as it could be a printer hardware.
Aug 02, 2014 | HP PhotoSmart C4480 All-in-One Printer ...
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
Everytime I try to print it says I have a paper jam. I have completely cleared all paper and it still indicates a jam.
Hi There,
This is a known issue with the
HP Color LaserJet CP 1215 Printer. If your printers formatter is gone bad then you'll have this kind of error with the light status on the printer.
All you need to do is to call the technical support of HP and get the formatter replaced for free if your printer is under warranty.
Hope this solution resolves your issue.
Please vote for me if your issue is resolved.
Thanks
Enjoy and Cheers !!!!
Nov 02, 2010 | HP LaserJet CP1215 Color Printer
Hello paper jam error appears with no paper jammed. Then printer refuses to print or doesn't print well
To resolve paper jam issue, follow the steps
1. Open the rear access door.
2. Remove any bits of paper stuck.
3. Clean the rollers using lint free cloth ( upward position )
4. Close the rear access door
5. Open the front panel door
6. Check for any paper stuck between the rollers.
After doing all these steps, to make sure if your printer is working fine, try to make a copy.
If the printer can make copy, Click on the link to resolve printing issue -> Link
Oct 12, 2010 | HP Photosmart 2575 All-In-One InkJet...
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
Printer Displays Paper Jam , Clear Paper Jam and Press OK. There is No paper Jam, No paper or torn pieces of paper in the Printer. The Printer is very rarely Used and is almost Brand New . (about 15 months...
Frequently this problem is caused by dirty feed rollers. Even dust accumulated inside a printer rarely used can cause this error. Sometime a door is ajar or not seated correctly. See this HP support article for information on how to resolve it. You may also need to refer here and here.
For other issue with your printer, or to pursue other self-help options, see the HP home support site for your model here. & here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
336 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
