SOURCE: rear window washer doesn't work
It may be broken. With that information, that is all I can tell you. Maybe more information? Isn't it still under warranty?
SOURCE: 2012 captiva, no heat, fan or ac. Outside temperature gage says -40. All fuses good.
go after relay , also check temp sensor
SOURCE: How do you reset the change transmission fluid light on a 2012 Chevy captiva sport?
You have to fix the problem. Once fixed you can clear it with a coder,scanner, or 50 key on and off.
SOURCE: No power to a/c, fan or heater to a 2012 Chevrolet captiva
You named off four things there that should have power. Which on doesn't? The A/C compressor(a/c), the blower motor fan(fan), the engine coolant fan/s(fan), or the heater/A/C control module in the dash? I suspect you have a bad blower motor resistor.
I have same problem it's not relay or fuse I'm finding that I'm not getting power out on fuse block 1 under hood and a couple in panel under dash now that being said they don't say ac or fan or climate related. Most are related to rear window defroster does this keep climate panel from working which in turn AC doesn't work I need answers please
