Question about Vector Camping, Backpacking & Hiking
I misplaced the owners manual for my vector 1097a smart battery charger where/how can I get one ?
Posted by alexander mason on
Gary F
    Sergeant:
  • 236 Answers
How would I go about getting a charger
Depend on what kind of batteries, and how often you are going to use the charger, and for what purpose are going to use it.
If your battery accidentally discharge far from your home a Jump Start is a must. But Car batteries are shallow Cycle and need to be fully charged. If you want to Set and Forget Charger, then a Smart Charger takes care on his one for the battery. Automatically adjust the voltage and turns off when the charge is completed. Has the Reconditioning option, can display the battery voltage, and can check the alternator. Destroying a $120 battery is more expensive than a Smart Charger.
I use a Vector Smart Battery Charger - 2/10/20 AMP 12V fully automatic.
Retail $49.95 I bought on sale CLEARANCE: $29.95
If you have cars not driven in daily bases, or go in vacation, a battery Tender is a good option too.
May 20, 2015 | Vehicle Parts & Accessories
How do you use the vector start it pro to charge a battery
The overall verdict is this is a poor quality jump starter which has an unreliable charger and a battery that will die if you don't look after it. However, I found one fair report on Amazon amongst many bad ones:
"The compressor on this unit, like so many others this small, is really only made for pumping up toys or bicycle tires. So don't buy this unit for that purpose. Go to a gas station with quarters and use their air vender.
If, like me, you bought a used unit, you will need to get both the manual and the charger. Do a search on servicenet dewalt to find the owners manual. The manual is a download pdf. Charger model number is 514005-42.
Hope this helps. It's really a neat little device to have around. I especially like the built-in LED flashlight.
You really NEED to read the manual all the way through. The special sealed type battery requires charging at least every 60 days or it WILL go bad quickly."
The Manual is here: http://documents2.dewalt.com/documents/English/Instruction%20Manual/Vector/VEC010BD.pdf
Because I'm an engineer I know I could easily replace the 12v lead-acid battery charger, open the box and replace the battery with another 12v say 200 Amp cranking (short circuit effectively) battery but I would tend to spend a bit more on a gel battery of similar spec 'cos it basically is the only sort that should be used for deep cycle discharge with such a small volume battery. Good luck.
Jan 25, 2014 | JUMP START SYSTEM
I have a Vector Smart Battery Charger 2/6/12 model VEC1088A-M. I am trying to charge a trolling motor battery but I get an error messager "F03." What does this mean?
F03 means 1 of 2 things:
INTERNAL OPEN CELL - Bad battery. Battery needs to be replaced or
SULFATED CONDITION - Battery needs to be reconditioned for 24 to 48 hours. See owner's manual.
May 27, 2011 | Computers & Internet
What does F01 code mean on a vector vec1097A smart charger
F01- Internal Shorted Cell Battery-(Cannot Be Charged) or
Excessive Load On Battery While Charging (Check Load)
*If this shows it is recommended to take your battery to a certified auto center for evaluation.
This Info Came Directly From The Manual.
May 02, 2010 | Vector Black And Decker High Frequency...
Camping, Backpacking & Hiking Logo
2,464 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
