Question about Vector Camping, Backpacking & Hiking
Code F03 on my Vector 1097a smart battery charger, what does it mean
Posted by alexander mason on
1 Related Answer
What is the error code f03 on the vector 1092 bettery charger
F03 - Sulfate or Unchargeable Battery
Appears when the battery is highly sulfated and cannot accept normal charge current.
• Follow the steps in "Recondition Mode" to recondition the battery.
• Follow the steps in "Equalizing" to equalize the battery.
• If the situation persists after reconditioning and equalizing, we recommend taking your battery to a certified automotive service center for evaluation
Aug 17, 2016 | Vector Camping, Backpacking & Hiking
How long does it take to fully charge a vector smart battery charger? When I unplug it, it won't power on unless it is plugged in. it is a VEC 1092 a model
The initial charge can require several hours, sometimes overnight. After that, recharges require less time. If your device doesn't turn on unless connected to the charger, the battery may be dead.
Apr 18, 2016 | Vector Camping, Backpacking & Hiking
My 98 blazer acts like the battery is dead but when i hooked it to a battery charger it said it was full and running at 9.1 when it should be running at around 12 then said error f03. so what does that...
It means the battery charger is your problem. Find an old-style simple battery charger, not one of these new "smart" chargers. The simple ones allowed YOU to decide whether to charge or not. Placed more responsibility on you, but a simple charger would WORK for your battery.
At 9.1V, your battery's DEAD.
Jul 12, 2014 | Vector Black And Decker High Frequency...
Vec 1097 A battery charger always give cod F03 with any battery
The battery in question so bad it wouldn't even register on the charger unit to any degree. I know this makes no sense, and kinda negates the whole point of even having a battery charger to begin with, but I learned of the battery it's attached to is too bad it won't even allow you to do ANYTHING with it.
Dec 06, 2012 | JUMP START SYSTEM
I have a Vector Smart Battery Charger 2/6/12 model VEC1088A-M. I am trying to charge a trolling motor battery but I get an error messager "F03." What does this mean?
F03 means 1 of 2 things:
INTERNAL OPEN CELL - Bad battery. Battery needs to be replaced or
SULFATED CONDITION - Battery needs to be reconditioned for 24 to 48 hours. See owner's manual.
May 27, 2011 | Computers & Internet
What does "sulfated Condition" mean
The battery is dry. It has insufficent acid in the battery
Feb 26, 2011 | Vector Black And Decker High Frequency...
Vector jump starter displays error F03
http://www.baccusglobal.com/bd/manuals/NEW%20MANUALS%20FOR%20WEB/VEC012POB%20MANUAL.pdf
Jul 27, 2010 | JUMP START SYSTEM
What does F01 code mean on a vector vec1097A smart charger
F01- Internal Shorted Cell Battery-(Cannot Be Charged) or
Excessive Load On Battery While Charging (Check Load)
*If this shows it is recommended to take your battery to a certified auto center for evaluation.
This Info Came Directly From The Manual.
May 02, 2010 | Vector Black And Decker High Frequency...
What does F03 mean
F03 is an error code with two possible meanings.
1) battery plates are sulfated, meaning they have a buildup of lead sulfate on the battery plates. Try charging the battery using the "Recondition" button on your charger. If this does not correct the problem then it may be option 2:
2) Open cell in battery. Have battery tested at an auto parts store and be ready to buy a new battery. An open cell means the battery is no longer usable.
Nov 18, 2009 | Vector Black And Decker High Frequency...
Camping, Backpacking & Hiking Logo
1,922 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
