Cars & Trucks Logo
Posted on Jul 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Speakers not working--FM and CD player shows it is
Help please! I travel and need my sound! Speakers not working--AM/FM and CD player shows it is working in the digital display. This happened after a guy trying to help jumped battery with wrong cable placement. I've already spent more than I have on fixing the other things that went wrong: shift module, new battery, brake switch, wiring harness...son thinks he could at least check it free to see if amp is truly gone--is there an easy way to check/fix this for someone who knows alot about replacing car stereo, etc.? Was told the amp is under the front passenger seat. Also, probably showing my ignorance, but would really like to know--I'm wondering why all of this happened in the first place--isn't this what fuses are for?
Anonymous
Level 2:
  • Expert 382 Answers
  • Posted on Jul 22, 2009
Anonymous
Expert
Level 2:
Answers
382
Questions
Helped
203924
Points
807
Dear friend-as you say the fuses are there to protect these devices,but sometimes things goes wrong.it appeares that the output channels on you stereo is blown,you will have to remove and have it checked.
1999 Ford Taurus stereo wiring diagram
These are the three top websites. According to Just Answer it came with AM/FM Radio, AM/FM Radio Cassette, and two types of AM/FM Cassette / CD Changer. All 4 are shown in the link
https://www.justanswer.com/ford/0hkix-find-1999-ford-taurus-stereo-wiring-harness-diagram.html
These are the other two websites.
1999 Ford Taurus Car Stereo Wire Colors and Locations
The12Volt https://www.the12volt.com > installbay > stereodetail
1999 Ford Taurus Stereo Wiring ; Ground, Black/Light Green ; Illumination, Light Blue/Red ; Dimmer, n/a ; Antenna, Left Rear ; Front Speakers, 5" x 7" Doors.
1999 Ford Taurus Radio Wiring Diagram
MODIFIEDLIFE https://www.modifiedlife.com > 1999-ford-taurus-radi...
Our 1999 Ford Taurus radio wiring diagram shows you all the radio wire colors and what they do. Table of Contents. 1999 Ford Taurus Radio Wiring Diagram; 1999 ...
.. Here is the AM/FM Radio wiring
1helpful
3answers
My radio go on but it's real low an only the front speakers worck is it a fuse or bad radio or bad speakers 2006 Pontiac Grand Prix 3.8 v six need help JT.thank u
The Entertainment System on this vehicle is configured with either a base or an uplevel system. Both the base and uplevel systems contain a radio, antenna, and speakers. An audio amplifier and digital radio reception (U2K) is available with the uplevel systems. Radio data system (RDS) is standard on all radios.
The following list shows the radios available for this vehicle:
• Base Radio (U1P)--AM/FM Stereo, CD with Programmable Equalizer, and RDS
• Uplevel Radio (US8)--AM/FM Stereo, CD MP3 with Programmable Equalizer, and RDS
• Uplevel Radio (UC6)--AM/FM Stereo, Integral CD changer (ICDX) with Progammable Equalizer, and RDS
So which of these systems does your vehicle have ? If it were a bad fuse it would not work ,just like Paula said . But to just say the radio is bad , can't agree with that . Does your system have an Audio Amplifier ? That could be the problem , your best bet take it to a qualified repair shop .
1helpful
2answers
Lost sound on 2005 impala. radio works. seems like amp problem.
Do you have base or up;level system ?
Table 1: Radio Features
Table 2: Cassette Features
Table 3: Compact Disc Features
Table 4: XM Advisory Messages
The radio receives power from the RADIO fuse in the junction block-right I/P. Ground is provided via G201 and G202. The radio is enabled/disabled by class 2 messages from the body control module (BCM). The radio routes audio signals from the digital radio receiver or the vehicle communication interface module (VCIM) to the speakers and/or amplifier when directed by class 2 messages.
The Entertainment System on this vehicle is configured with an AM/FM stereo radio with the radio data system (RDS) and either a cassette player or a CD player or both. CD and cassette. The uplevel system provides the customer with extended range speakers and an audio amplifier. Satellite digital radio (U2K) is available with uplevel systems.
• Radio (ULO) - AM/FM Stereo, Cassette with RDS
• Radio (UNO) - AM/FM Stereo, CD and RDS
• Radio (UPO) - AM/FM Stereo, Cassette with CD and RDS .The complexity of the radio systems on these vehicle is mind blowing .
Your best bet take it to a GM dealer , has features you are unawear of .
DTC B1025, B1035, B1045, or B1055
When the radio is powered up, the radio supplies low level audio signals to the speakers. If the vehicle is equipped with an audio amplifier, the amplifier will boost the signal sent to the speakers.
DTC B1025 Audio Output Circuit
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, monitor the DTC Information for DTC B1025.
Does the scan tool indicate that DTC B1025 is current?
I have a CD and in my car it won't playback discs. It allows me to insert/read the disk, it even shows the data, track number, and position in the song but it won't play to my speakers. The AM/FM...
What i found i have had that problem in the past,This may sound stupid but it works.Spray aftershave over the cd then push the cd into the player when the aftershave is wet.This will clean out the dust inside your cd player .i can say this will do no harm.ok pippall,Hope that solves it for you m8.
5helpful
2answers
Truck Radio/CD Player, no sound coming out of speakers
Have you check the mute mode, maybe it is in mute mode.
1helpful
2007 CRV AM/FM radio works fine but CD player does'nt work
Sounds like the CD changer is defective, sometimes the dealer will offer a "one time goodwill" repair when it is out of warranty for miles but not for the time period. Check with the dealer where you purchased the car.
55helpful
4answers
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
2005 Dodge Caravan Stereo Mode won't go to CD
i would take back to dealer and tell him it dont work, maybe he forgot to connect a wire.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
