Refrigerators Logo
Dolf Posted on Jan 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung SR-L709EVSS Refrigerator/freezer runs and cooles. Then stops and defrost everything and starts again. Repeats all over again. Did change control card and lcd but still same problem
Electro Med Services
Level 3:
  • Samsung Master 6,694 Answers
  • Posted on Jan 22, 2017
Samsung Master
Level 3:
Answers
6694
Questions
Helped
1870190
Points
21433
If you wish to get some details about refrigerator common fault and troubleshooting ; visit the site linked here. Pull up older posts. search with the word "Refrigerator"...
http://electro-medical.blogspot.com/
5 Related Answers
A
Anonymous
  • Posted on Mar 09, 2007
SOURCE: Frigidaire Model # FRT15G5AWO Top Freezer Refrigerator
frigidaire makes a garage kit to operate refrigirators at lower temps. the kit is about 18.00 dollars, it is avaliable from electrolux,1800-599-7569
butch welch
  • 147 Answers
  • Posted on Sep 23, 2008
SOURCE: I have a Samsung RS2556BB
Justy a piece of junk. The display has nothing to do with the defrost. Hold your top two buttons for 10 seconds and the displays will reset..good luck.*****
Anonymous
  • 163 Answers
  • Posted on Jan 05, 2009
SOURCE: SAMSUNG REFRIGERATOR MODEL SR-368 freezes and no cooling.
Hi!!! You have a defrost problem.You need to change the defrost timer mechanism.In Samsung frig the defrost timer is in the main pc board..Good luck..
Anonymous
  • 700 Answers
  • Posted on Feb 22, 2009
SOURCE: refrigerator stopped working
ok whats the light that you see? i need to know what the bars are and or your email and i can email you the list for the codes.
Anonymous
  • 14 Answers
  • Posted on Jul 07, 2009
SOURCE: Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
My Samsung CoolTech Model SR-L709EVSS fridge and freezer works for a few days and then goes off by its self and then works again. What could the problem be?
Only time these units completely shut down is when the defrost timer shuts down all power to the compressor and condenser/evaporator motors. Only the bulb works.
If that timer gets stuck somehow that would explain the complete shutdown and mysterious restart later .
Why as food suddenly started to defrost in freezer
If the fan is running in the freezer and there is some cooling, the evaporator (cooling coil) is probably iced up due to failed defrost timer or heater.
Hi, SAMSUNG SR L39 stops to cool, even if everything seems ok, the fridge is on, the display lit, but food is not cold. Then turn off and turn on the fridge by the power button and everything seems to go...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
My samsung fridge section stops cooling but freezer is working
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
2helpful
Freezer and fridge don't cool at all. everything else works fine
Heya,
There is a fault with samsung fridges that when it goes on defrost it will not start the compressor or the fans again. If you turn on the power the fridge should run for a couple of hours and then stop if so you will need to get a tech out to order a samsung yellow sensor and a fridge defrost isolation sensor. If the fridge does not work at all if you would like i will talk you a couple of little checks before calling someone out.
Hope this helps
1helpful
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
