Confidence GTR Power Pro Motorized Electric Treadmill with adjustable incline Logo
M
Michael Deans Posted on Jan 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Confidence Gtr power Pro pulse rate goes very quickly to 90 but even after completion of programme remains at 90. It won't go above. Why?
Electro Med Services
Level 3:
  • Confidence Master 6,694 Answers
  • Posted on Jan 20, 2017
Confidence Master
Level 3:
Answers
6694
Questions
Helped
1871087
Points
21433
If you wish to get some details about treadmill repair and service ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
2helpful
2answers
I am a woman of 66 years old with a blood pressure reading of 110/60 and a pulse rate of 70. Is this normal?
there is no such thing as normal but an average for your health
see your doctor and get what he considers an average from your past records and use that average as a guide for your readings
1helpful
Display is showing 3 dash marks. the treadmill will not come on at all. please help
You may have a control board failure, it must be checked by a repair tech.
How to tighten drive belt
Hi. The only way i can see is to adjust the roller screw on the opposite side of the main belt. Rubbish design. Then when motor belt is tight enough adjust main belt to run straight. Mine ended up running diagonal to stop the motor belt slipping. :(
2answers
My jeep won't start or even turn over
you need to check the voltage at the battery when you have trouble. should always remain above 12 volts.
If not then the battery or the connections are bad. first test the battery right at it's lug terminals, then check the terminal connectors. battery or cable or connectors - def sounds like major voltage issue in the battery area!
6helpful
2answers
How do you read a wrist tech monitor and what does the number mean?
The wrist monitor, much like ones in doctor's offices, reads your blood pressure and pulse rate.
The large numbers are your blood pressure reading. The Top number is the Systolic and the bottom number is the Diastolic. If you doctor or his nurse has taken your blood pressure and told you what it was, they said for example, 140 over 80, which on your chart would be listed as 140/80. The smaller number at the bottom of the screen is your pulse rate. Some monitors will indicate if the heart beat is regular or irregular. Depending on your age, general health and life style, a normal blood pressure would be in the range of (Systolic) 120 to 130 over (Diastolic) 70 to 80. But, your normal range may be different based on what I said above. Only your personal physician can tell you what yours is or should be.
When using a wrist monitor it must be properly placed on the wrist (1" above the heal of the hand). You must remain very still and try not to talk, until the monitor has completed cycling. Also, having your hand/wrist at heart level, helps to ontain a more accurate reading. Never take readings back to back. Wait at least 2 minutes in between sessions.
If this helped you, please be kind enough to let me know.
Rich
EMT
Programmes in washing mashine Eurotech FL 807 are really long (very old washer?) I want to run an empty mashine on 90 degrees (C) to clean it, can I combine hot water with a shorter programme although the...
yes - there is no thermostat to tell it the water is warm - go for it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
2answers
WD440 drying high heat and 0n/off light flashing
Just had the exact same problem and think I may have solved it. even turning power off didn't solve it. I think what happened was that the programme had been interupted while drying. I tried everything to get machine to work afterwards but only the following worked - while lights are flashing put back to the same time I had set to dry (60) in my case and turned the dial to M for dry high heat light goes off after a short while - leave for 5 mins then press off. machine will make a noise for a short while then stop.
If this happens then machine should be back to normal.
this is same for both posts I guess.
URGENT HELP NEEDED (editing a film) G4 0S 10.4
It sounds as if the enclosure has failed. IF THE DRIVE IS GETTING POWER, but not making strange noises, you may just need to extract the drive from the enclosure. Keep your fingers crossed. If the drive has been affected, data recovery may be the solution. Good luck.
Top Confidence Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Confidence Exercise and Fitnes Expert? Answer questions, earn points and help others
