SOURCE: What is the meaning of 3 long beep of Soltek mainboard?
Try the following. If you are comfortable inside the machine.
Discharge static by touching the metal of the computer case
2.) Unplug and reseat all cards in system Video Sound etc.
3.) reseat ram chips in slots
You should be good after this.
SOURCE: F1 is displayed on Maytag Electric Oven
Hi
F1 error means that you have either a bad ERC (clock) or a bad
touch pad. To check these please follow these simple instructions:
thank u
rate me!!!
SOURCE: Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
SOURCE: Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
SOURCE: self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
