SOURCE: protection light on
go to power acoustiks website at: poweracoustik.com then tech support look at how to insatll an amp
SOURCE: Akai LCT2716 Flat Panel TV
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
SOURCE: my ps3 suddenely turned itself off mid-game.
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
SOURCE: rapid green blinking green light on monitor and power & no video
try to acces the menu and to reset the display settings.
try another monitor on your computer to be sure that your video board is working, and if it is change the resolution in 1024X768 and try again your dell display
