Question about Lite On Televison & Video
Lg60pb6650 stand lite on -turn on with remote relay clinks -screen flashes gray - then repeats -found 2nf capacitor blown on upper buffer board-tried to replace the capacitor but hard to do. Reinstall
Posted by Greg Pitoniak on
  • Greg Pitoniak Jan 18, 2017
    After reinstalling upper buffer board I power up tv and has the same symptoms as I stated above . Could the y sustain board be causing the problem blowing the buffer board cap?
  • Greg Pitoniak Aug 22, 2017
    Y sustain board was also bad -replace y sustain and power up beautifully. I was successful soldiering the 2uf cap on the upper buffer board.
    Top Expert:
  • Lite On Master
  • 76,719 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Jan 18, 2017
5 Related Answers
Anonymous
SOURCE: Y Upper Board
It looks like GUEST is a little anxoius about your helpful forum here.
Posted on Sep 24, 2008
Anonymous
SOURCE: Screen went black, found blown FS2 on Y sustain board, replaced
Same thing happened to me. I called HP, and they said that they knew about this issues since about 2006-2007, and had been fixing it for customers up until 6 months ago. Now? You're out of luck. HOWEVER, I'm committed to getting their attention on their forums. Join the fight!
http://h30434.www3.hp.com/psg/board/message?board.id=Other1&thread.id=548
Posted on Aug 29, 2009
Anonymous
SOURCE: Y - BUFFER BOARD - PCB: LJ41-02760A : Parts FOUND!!!!
You can also find it here: http://www.itritek.com/ysusbufferforsale.html It's a lot cheaper than partstore and they offer repair too.
Posted on Sep 22, 2009
Paul
  • 381 Answers
SOURCE: LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
Posted on Mar 26, 2010
theotherm1ke
  • 19 Answers
SOURCE: Apex dt250, capacitor blown. I would like to know
The DT250 has one or more bad 470uf 25v capacitors. You should replace all four. Look at some of these youtube videos for how do do the replacement.
http://www.youtube.com/watch?v=on_2CP52cW4
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Order 4 new 470uf 25v capacitors from digikey.com P/N P10274-ND
Use first class mail as your shipping method. Will be under 10 dollars total.
Posted on Oct 08, 2010
Replacing capacitors
check upper and lower buffer boards for blown chips
Samsung LC32C350DLD won't power on, red power lite is on but remote and button on tv does not turn it on! Blown power board?
it may be the stand by chip on the main board check that there is volts getting to the standby side of the main board.also check power board for weak capacitors in line.
Blue power light flashing on and off, but no picture
check for puffed up capacitors on main board usually 3300/100v bigger ones on board replace and then check buffer boards upper and lower for blown chips if so replace
Blinking blue power light
check buffer boards for blown chips but before check main board for puffed up capacitors need to replace bad capacitors on main board usually 3300/100v ones bigger ones on board then check buffer boards for blown chips usually bottom buffer board
Flashing screen
if its flashing upper half its buffer board if its flashing whole screen its upper and lower buffer assy.
5helpful
2answers
No picture, just sound, blown y buffer board twice1
a4.. there are 2 of them, upper and lower buffer boards.. they control the top and lower half of screen devided horizontally, i have had many run ins with these sets. and usually the buffer boards arent cheap.
they plug into the ysus( y sustain).. its possible your y sustain is blowing the buffer moduals because one of its i.c.'s under the heatsink has popped on ya.. effectively creating a short that blows the buffer boards.
remove the buffer boards, turn tv on... feel the 2 silver heat sinks on that y sustain( beware dont zap urself.. just the tip of your finger on the heatsinks)
you may find that one is cold and one is hot...if so, you need a new y sus and probably to replace the buffer boards the a4 upper and a4 lower.
If you get a new ysus.. plug the a4 upper and lowers into it, look at your picture.. if ur missing the top half the top buffer is blown or lower half the bottom buffer is blown. or..no picture they could both be blown..an easy way to tell if u have no picture to diagnose is..touch the heatsinks that sit over the chips on the buffers..if they are red hot.. they are bad and shorted internally.
50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
1helpful
2answers
Philips 42PF7320A/37
a 7 bliink error for this model is an 8.6 volt error normally caused by the y main overloading the power supply. disconnect the y main from the power supply and if the tv starts up check primary voltages per power supply sticker on pdp and if correct replace y main and y upper and lower buffer boards as they work together as circuit
2helpful
We have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
Televison & Video Logo
Top Lite On Televison & Video Experts
Ekse
 Francisco Mauricio...
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
