Question about Rangemaster Kitchen Ranges
Rangemaster part 2995 A119
Where can I buy this part. it is the control switch for an old rangemaster ovenhood
Posted by Gerald Cole on
dik stukkien
    Scholar:
    New Friend:
  • 69 Answers
Hi Gerald,
for old Rangemasters it is difficult to find the original parts, as they have their outside model.
But when you open the switch carefully, you will find 2 switches on a board, one for the light and one for the fan.
These parts are common for a lot of cooker hoods. The switches look like the one of link 1
Genuine Creda CRV10W Light Bulb Switch Cooker Hood eBay
the second link gives you a complete unit, so the light switch and the vent switch on a board
https://shop.ukwhitegoods.co.uk/08086215-hygena-cooker-extractor-hood-switch-pcb
I hope you will find the right part.
Kind regards, Dik
Posted on Feb 17, 2018
1 Related Answer
Anonymous
  • 188 Answers
SOURCE: Push button controls for Rangemaster kitchen hood don't work
rangemaster do have parts for items they supply and a good help desk. find the number on the internet. sounds good what you think. but better to get the part. hey.
Posted on Mar 25, 2009
The shower control valve for my moen 2995 faucet is stuck in the shower position. how do i remove it?
Turn off water main. remove round cap on face of handle, remove screw and pull handle. After that everything else can be pulled off easily. When you get to the diverter you should be able to why its stuck.
Sep 27, 2009 | Moen 2995 Chateau Three Handle Tub and...
Rangemaster 110 oven heats by itself
That happens either because the timer control is faulty, or because there is a contact on the element wires or connectors, and the element is grounded.
Control board and wiring harness are tested using a multimeter.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 17, 2009 | Rangemaster Professional 90 SS (electric)...
Mar 22, 2009 | Rangemaster Kitchen Hood
Rangemaster 110 gas model
I have downloaded the users guide from rangemaster.co.uk which has details of how to change parts & a wiring diagram, Hope this helps. Here is a section..............
5. To Remove Clock
Disconnect from electricity supply.
Remove the Control Panel (See 2). Pull off the timer
control button(s).
Remove the timer/mounting bracket assembly from the
control panel by removing the fi xing screws.
Remove the timer from its mounting bracket by
depressing the plastic lugs on the timer case, at the
same time pulling the unit forward.
Reassemble in reverse order. When replacing leads
refer to the wiring diagram. Check operation of timer.
BEFORE SERVICING ANY GAS CARRYING
COMPONENTS TURN OFF GAS SUPPLY.
Sep 07, 2008 | Rangemaster 110 (Gas) Kitchen Range
The colour is coming off the oven knobs and the control panel.(brass fittings)
This is a common problem, I repair these for Rangemaster so I suggets that you contact their customer service department they usually replace then for free
Nov 15, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Oven fan noisy/broken
this noise probably means that the fan is about to stop working, this is what happened to mine. You can easily buy replacement fan off E-bay (it seems easier to find the right fan on e-bay that any of the confusing supplier sites). You then just need to remove the inside oven back and the outside electrical to replace the fan.
Sep 24, 2007 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Cooker stuck on auto
Comes on like this when switched on, hold down the left 2 buttons on the clock controls then whilst still holding them pres the right hand button
or manuals available here...
http://www.rangemaster.co.uk/index_Rangemaster_Manuals.htm
Sep 18, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Kitchen Ranges Logo
47 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
jdthefixer
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
