Cell Phones Logo
l
lisa licon Posted on Jan 17, 2017
I just bought the phone and when i turn it up it says i have to set up my jittebug account and it says pick easy to use jitterbug but it keeps saying please wait
Matthew Adeleye
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jan 17, 2017
Matthew Adeleye
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
356
Points
9
Make sure your internet is strong and stable...make sure your wifi is off if you are using your phone data, or make sure your phone is on flight mode if using the wifi
My Jitterbug Flip 2 has text issues, how do I fix it!
This is $100 budget phone for seniors, so I am thinking the quality must be low. However the problem states that poor signal and network strength is the issue. You need to contact your Telco about the reception where you live. Low signal strength can also be caused physically where you live, say if you live in a basement apartment within a family home.
https://www.google.com/search?q=Jitterbug+Flip+2
Oct 14, 2022 • Cell Phones
My jitterbug smart phone keeps talking and saying unlabeled won't let me go to home screen
Probably in narrator mode, tap what you want to open than double tap to open. Scroll with 2 fingers. Go to settings, accessibilities and narrator mode and off. If that doesnt work there could be a button combo to turn on and off.
Apr 04, 2019 • Cell Phones
Jitterbug phone won't turn on. When sitting in charger, the light comes on as normal
Check and be sure it was actually charging when it was sitting in charger. Also, sometimes lint or other fiber can get in the phone jack and keep it from getting a good connection. If you suspect that, use a tooth pick or a cotton swab with the cotton removed and GENTLY pick out any that is in the jack then place it in charger again and see if charging light is on. The following is an IPhone but it is generally the same with any ...
Jul 10, 2018 • Cell Phones
5helpful
How do you turn up the ringer volume on the Jitterbug phone. It's currently set on vibrate & I don't know how the volume got turned that far down.
First, make sure your Jitterbug phone is turned on and open. While looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume. The inside screen will display the ringer volume level. The ringer volume ranges from Vibrate to Max.
If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
How do I use the calendar on my jitterbug J. There are no instructions in the manual.
To add an event to your Calendar, either create an account and login to MyGreatCall.com or call our Operator Services by dialing "0" and then Yes on your Jitterbug phone. There are no monetary charges for calling the operator, but it will use your standard minutes as with any other call and there is an additional 5 minute charge when connecting with the operator.
If you would like step-by-step assistance with adding an event online, please call our Customer Service department at (800) 733-6632. We are available 24/7.
Does Jitterbug take messages?
Jitterbug Simple Text Jitterbug Simple Text is an easy way to send and receive text messages for only 10¢ per text message. You can type and send a custom text message of your own or choose from our convenient Jitterbug Library of pre-written text messages, with no typing required.
Jitterbug Simple Text is perfect for anyone who prefers simplicity and wants to stay in touch without using minutes. We’ve made text messaging easy to use by providing you with a variety of pre-programmed text responses from which to choose. If you have a Jitterbug J, you may also create and send your own custom text messages. This helpful new service makes text messaging easy and it costs just .10¢ per textmessage.1
goto http://www.jitterbug.com/
for details
1helpful
Delete call history?
We at Jitterbug are dedicated to providing great service. I am part of the Jitterbug Customer Service Team, and it’s my job to make sure things like this get made right, and right away.
You cannot delete from call history. However, the phone keeps a list of the 10 most recent outgoing, incoming and missed calls. After 10 entries , the oldest call is deleted. If you need any further assistance you can contact me at [email protected] . Thank you, Debra
The Jitterbug phone is charged but it will not turn on. Any ideas?
We at Jitterbug are dedicated to providing great service. Thank you for bringing this issue to our attention. I am part of the Jitterbug Customer Service Team, and it’s my job to make sure things like this get made right, and right away. I would like a bit more clarification please. Once your Jitterbug is completely charged and you remove it from the charger, what happens when you press the "On/Off" button to turn your Jitterbug on?
How do I turn off music that plays when I turn the phone on and off?
You are referring to the Jitterbug Jingle. This jingle cannot be turned off on our Original model, but if you have the newer model, the Jitterbug J, this can be done.
From the menu, press the down arrow until the option Settings is highlighted in the center. Press YES to select. Press the down arrow until Jingle ON is highlighted in the center. The question at the bottom should read TURN OFF? Press YES to toggle between Jingle ON and Jingle OFF.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
