Question about Audio Technica Audio Players & Recorders
Audio Technica service centre in Kolkata for AT LP 120 Turntable Table
5 Suggested Answers
Anonymous
  • 94 Answers
SOURCE: Service Centre
hi
call n 18004254515 or email on [email protected]
u can be rest assured hat its great service of replacement for kingston in india and very prompt too
Posted on Jul 02, 2008
Anonymous
SOURCE: Audio Technica AT-LP2D
Mine had the same problem. It was under warranty and Audio-Technica replaced it promptly.
Posted on Jun 20, 2009
Tony A
  • 189 Answers
SOURCE: brand new audio technica at-pl120
HELLO!
I don't know which country you are from, but if the mains plug has a fuse in it then replace it with the same type. If that does not do the trick take it back back where you bought it and get a refund or a replacement! There may well be an INTERNAL fuse inside the unit on the power supply unit which may be at fault. If it is under warranty don't open the turntable yourself - take it back - I WOULD!
All the best!
Posted on Jul 22, 2009
Anonymous
SOURCE: need gigabyte motherboard service centre at kolkata
hi all 5 months ago i have purchase a intel processor duel core 2.5 and gigabite DG31 motherboard and 1 gb ram DDR2,but last some time i am suffring some problem when we copy any file my system take more time any one tell me whats the problem. Mukesh Dhiman 9958350728,[email protected]
Posted on Jan 18, 2010
howcanwe
SOURCE: service centre in kolkata for canon
CANON MASTER SERVICE CENTRE 3A, 1ST FLOOR, SHAKESPEARE SARANI,
KOLKATA
WEST BENGAL
Pin : 700071
Tel : 033 - 40110710/11
Email : [email protected]
Contact Person : Ms Sharmi Chaudhary
Timing: 9:30AM to 5:30PM
Posted on Dec 07, 2010
Where is the audio output hole on the Audio-Technica At LP-120 USB turntable, so I can connect to my stereo system?
After reviewing some of these unit being sold on e-bay, I found some pictures that show the cable coming out of the bottom of the unit. I then went to this site
The most detailed Audio Technica AT LP120 USB Review and according to them, the cable is hard wired. This means the cable is not removable. If your unit does not have the rca cables coming out of the bottom of the unit, it may have been cut off.
Jan 03, 2018 | The Audio Players & Recorders
Audio technica at 120 cartridge will fit my project essential?
Having looked at the turntable it seems to mount the cartridge with two bolt like fittings. The Cartridge you want has two mounts on the side that will take those bolts.
You will have to adjust the arm to compensate for the weight differences between the two cartridges, but once done it should play fine.
Jul 18, 2016 | Audio Technica Audio Players & Recorders
Using turntable (audio technica at-lp 120) with built in pre amp the sound is distorted and broken up. the turntable requests phono turned on to use. Does the receiver have a pre amp or boost signal...
A turn table produces sound voltage in the millivolt range. If you have it connected to a receiver that has a phono input and the turn table is pre-amplified, you are overdriving the receiver and it is clipping the audio and making it sound bad.
Jan 17, 2015 | Yamaha RX-V592 5.1 Channels Receiver
I bought an Audio Technica USB AT LP 120 Turntable last June. It worked fine as a turntable, but I was never able to get good recordings of vinyl without distortion. But now I have another problem: when...
Sorry it could be the cartridge! They can fail at anytime, only the stylus will wear with time. However it could be the amplifer's magnetic cartridge pre-amp. If you look inside your amp and trace back from the phono socket you should find the pre-amp. If it is distorting on both channels it's probably an IC that has failed.
Dec 05, 2010 | Audio Technica USB Turntable
Audio technica lp 20 usb the belt is out of place and I do not know how to put it back as it was
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Oct 11, 2008 | Audio Technica AT-PL120 Turntable
Mar 02, 2008 | Audio Technica AT-LP2D Turntable
80 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
GFXTech
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
