2003 Cadillac Escalade Logo
B
Bob Cejka Posted on Jan 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The front seats for our 2003 Escalade will not move forward or backward and the heat control for the front seats will not work.
Jeff Armer
Level 3:
  • Cadillac Master 15,575 Answers
  • Posted on Jan 16, 2017
Jeff Armer
Cadillac Master
Level 3:
Answers
15575
Questions
Helped
7104974
Points
73899
Does your Escalade have memory seats ?
There are 2 options of power seat systems available in full size trucks. The 6 way driver and passenger power seats, and 8 way driver and passenger power seats with driver memory. For the driver memory seat operation refer to Memory Seats Description and Operation . Power seats without memory are completely controlled through the power seat switch. Battery voltage is supplied to the power seat switch through the power seat circuit breaker. While the seat adjuster switches are in an inactive state the switch contacts are closed to the power seat switch ground circuit. When a power seat switch is pressed to an active state the switch contact is closed to the battery voltage supply circuit. Each seat adjuster motor is controlled by the power seat switch through 2 motor control circuits. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
2helpful
Power seat won't move backwards
I had the same problem some one on one of the web-sites solved his problem by banging on the track rail in the front while pushing the seat button back after a good few bangs it unjamed and works great now .I feel like I saved at least $1500 by dealer rates.
2helpful
2answers
2001 Nissan Altima front power seat does not move forward or backwards. Seat does raise and lower
needs a forward/rearward motor. it has two separate motors under the seat. very common and i replace them all the time. good luck
The front heated seats on my 2005 Cadillac Escalade ESV stopped working and I can't find the fuse that controls these
a relay controls the heated seats then linked to a circuit breaker instead. the relay is more than likely the problem
13helpful
Power Seat Control does not move the seat front or back
Try tapping the power seat frame with a hammer to unbind the motor .
5helpful
2answers
2003 escalade rear climate control no heat just cold air.
there are two separate actuators for the rear system. one controls temperature and the other controls vents from head to feet. mine problem was the later. that acutuator for esv 2003 is 89018365. it is located just below third seat cup holder passenger side and can be replaced simply by removing cup holder. triangular shaped part with wire harness.
2answers
Power Seat on Drivers side want go forward or backwards. It works in the other positions but now forward or backwards.
Good day;
What year is you car? Does the other controls work for the seat? and just to clarify the seat won't go forward of back?
Cheers
Top Cadillac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Cadillac Expert? Answer questions, earn points and help others
