If your TVBP-BTN wireless stereo headset is not charging properly and the blue light is not showing, there are a few things you can check to fix the problem.
SOURCE: Polaroid FLM 2011
have a tech repair your tv the problem is in the power supply and related circuit.good luck.
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
SOURCE: headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
SOURCE: The blue light on my base unit is on but the headset does not app
Unplug the unit -- Then grab the ear peice, and slide off the battery, wipe off the metal prongs ...leave apart for a couple minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the battery to charge. But this should solve your issue.
SOURCE: Bluedio T9 Bluetooth won't charge
Well... I've got the n65, and this is the third time I've gone to charge it. Solid red, won't turn on no matter how long its been plugged in, can't find the manual, this fixya page is the best result online...so my solution is to stop by the local cell-phone accessory shop to buy something new.*
*Results may vary. :^s
