Question about American Standard Home
My American Standard whirlpool tub is spraying water out of the two rear (highest) jets. All other jets are working normally.
Posted by Hank on
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: Whirlpool pump only buzzes.
Well there are two things....You say "buzzes?" Like pump is running "humming" & not pushing water. That would be an "airlock" in the pump & it needs to be primed.
If it's "buzzing" & pump motor is not turning (Like it's froze) you might have a bad start up capacitor on the pump that needs to be replaced. Worst case scenerio entire pump needs replacement.
Posted on Jan 14, 2009
Anonymous
  • 125 Answers
SOURCE: my whirlpool bath tub has three jets that work & 3 jets that are
The suction IS the water intake. it takes the water from the tub into the pump and the water comes back out through the jets.
Posted on Feb 24, 2009
bwbconstruct
  • 23 Answers
SOURCE: Button on American Standard Whirlpool tub is stuck
most tub buttons are attatched to a small air tube thats connected to a switch. if that tube came off the button wont work. just look inside your access panel the tube will be there check both ends if one came off vut 1/4 inch off and reattach
Posted on Jul 20, 2009
Alan
  • 80 Answers
SOURCE: how do you remove the jets on an american standard whirlpool tub
The jets have a nut on the back of the jet. I hope you have access or else you will need to pull the tub for this job. Loosen the nut and squeeze aquarium grade silicone in between the tub wall and the nut, Tighten the nut, but not to tight. Let set over night fill and check for leaks the next day.
Posted on Sep 19, 2009
Anonymous
  • 31 Answers
SOURCE: My American Standard whirlpool pump will only hum.
The bearings (or bushings) of the pump or pump motor have siezed, these can be replaced on some models but for the most part you will need to replace the pump and/or pump motor. and as where to get parts, i would suggest the outlet from wich you purchased the unit or another appliance outlet. Or if you feel up to the challenge, im sure you could find replacement parts on the internet: google, ebay, etc.
Posted on Sep 30, 2009
Hydromassage 1063
Not normal for that to happen but the jet faces on the two back jets may be turned off or down.
Try turning the face of the jet clockwise and see if you get more water flow out of each jet.
Rod
US Parts Center
Apr 13, 2014 | American Standard Home
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
My American Standard spa tub Williamsburg Elite Model 2425E has a couple of the eight jets failing to jet, the two on either side of the rear left corner.
sounds like maybe the jet faces are turned off. see if they turn one way or the other and they may open and spew water out for you.
Dec 31, 2010 | American Standard Home
I have an american standard jet tub, but i lost
You can adjust the jets by moving the center of the jet around, if the center does not move, it is not adjustable, some jets have a pressure adjustment by twisting the center of the jet left to right. No manual necessary for this.
Mar 13, 2010 | Home
Water runs very slowly when trying to fill jet tub.
Check to see if there are any screen type filter to the tub as debris may be clogging it. Also air lock can occur but it should not be causing problems as 90% clear them selves.....
Feb 15, 2010 | American Standard AMERICAN STD Savona...
Two jets stopped working
Most of these jets turn to close. Check if you turn the nozzle. Hope it helps
Jun 04, 2009 | American Standard 2770.018w.020 Cadet...
We have purchased a whirlpool tub model # 1714019020. It has side jets & 4 jets at the back. Can you tell me if there is some way to adjust the back jets or to turn them off as they spray water everywhere...
Some jets you can stick your finger into the jet its self and move it in 360 degrees. Others have a notched round trim piece that when turned counter clockwise, will loosen the jet where you can manipulate it as described above. You will need to retighten it after your done so it doesn't end up the same way. If you have trouble, you may want to use a little spray lubricant on it so it will loosen.
Mar 31, 2009 | American Standard Home
Home Logo
47 people viewed this question
Top American Standard Home Experts
Mike
john h
Bill Johnson
Are you an American Standard Home Expert? Answer questions, earn points and help others
