I have power, but no picture. All I see when I turn on TV is multi-color vertical lines. No images or sound. Looks as if bars and tone have taken over complete screen. Any ideas?
Maybe power supply, color wheel or capacitors?
Help!
Thanks
SOURCE: flm 3232 polaroid
The power supply is only supplied with the control box. The control box is listed below.
Polaroid FLM3232 Control box with Power Supply
SOURCE: Polaroid LCD TV FLM-3232 turns on, then turns off
well..yes..that is true...any chance it under warranty?
SOURCE: Polaroid LCD FLM-3232 Television
I can only tell you what I found out. There is vertually no documentation supporting this product to componant level, so I just had to wing it.
I had no power 24VDC from CN2 or CN3. I figured the problem was a switching problem,
So I replaced two Diodes D7 and D6 (They are in the mid board area and real close to each
other) I also replaced the two electrolitic caps 10UF 50V that are in the same area just
because I was in the mood to change out parts. (I changed em with 10uf 35V) the diodes
were also changed with parts I could get D6 I changed with a 276-1102 and D7 with a
276-1114 Radio Shack. I know that they are not the correct values, but I was in a hurry
and just wanted to see if I could some it and get it off my table. Well Low and Behold''
it sturned on, and has been working. I cant say this fix will help you, but if that other
harolded fix does not work for you, then try mine. worst you can do is Blow it up. I really
Should have taken the time to order the correct parts, but after pulling my hair out for two
days trying to find a schamatic for that stupid power supply I guess I got depressed. I knew it had to do with the switching on of the power, but so many things can do it. I just hoped it out be those swistching diodes. If you do want to try this, go ahead and remove the componants and order
the correct ones. and GOOD LUCK.
Alan LaBerge
SOURCE: Polaroid Model FLM-3232 Television
Most likley it is the main processor on the main board..You cannot replace this processor.Go to shopjimmy.com and see if they have just the main board.
SOURCE: FLM-3232 Screen Shattered
ky9c1le,
I have a flm3232 with a dead supply (I think). Maybe we could strike up a deal. Contact me at [email protected].
