Question about Ariston Technologies Ovens
Control panel on my ariston oven the setting have wiped off . would like to know were to set the fan knod to bakeThe signs for the fan setting have been removed over time
Posted by Beverley Woodward on
5 Related Answers
the dr
joey shearer
  • 447 Answers
SOURCE: Control Panel
Yes actually i do..... open the lower oven door next to the hinges are 2 small phillips screws, securing two long metal side trim pieces. remove trim. Exposes two more phillips screws Control lifts up and off then Make sure unit has been powered down !!!!!!!!! If the old control is totally blank there is a thermal fuse that has gotten too hot. PLEASE rate my solution...Thank you
Posted on Oct 03, 2007
Anonymous
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
grandadfixer
Reg Woolley
  • 99 Answers
SOURCE: ariston oven fm51ix
new knob req Email model no and seriel no we can supply parts. [email protected]
Posted on Jun 11, 2009
Bruce Hathcock
  • 3600 Answers
SOURCE: Ariston FM22 Oven No Control decals
Go to this site www.appliancepartspros.com and look up your model there and you can order the decals or replacement knobs there.
Posted on Nov 29, 2009
Anonymous
SOURCE: how to remove the control panel on Whirlpool double oven Model RBD305PDS14
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
We are about to move into a house with a Ariston wall oven, model no: FB 86 C. All the symbols around the 2 knobs have been rubbed off, is there a transfer or someway of finding what the symbols should...
This is a normal feature for this brand. The decal comes off when cleaning with anything other than pure water. They will sell you a whole new oven front for about $100 so you can do it again next time you wipe down the front panel when cleaning your work top. Please complain to Ariston head office and tell them what you think of their product. The manual doesn't show the detail so I guess you will have to buy either a proper oven or get ripped off by Ariston for a new panel ( you could always send the new panel back after copying the letters). I'll never buy an Ariston product again.
May 02, 2010 | Ovens
Got a fan assisted gas oven. Trying to bake a cake
Temperature control with gas ovens is not an exact science. However the control should be better than you say.
Have you tried reducing the set temperature to compensate for the 'overshoot'. It may be worth a try.
Jan 04, 2010 | Ariston Technologies Ovens
Ariston oven fm51ix
Jun 11, 2009 | Ariston Technologies Ariston FO98P...
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Control panel
generaly the only way to reset is by turning off the power to the oven at switch board for at least 30s. if this does not work check the back of the digital panal for any burn marks as it may have shorted when it fell back, also check any wiring connectors have not come off
Feb 18, 2008 | Ariston Technologies Ariston FO98P...
Ovens Logo
62 people viewed this question
Top Ariston Technologies Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
john h
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
