Question about IBM ThinkPad T43 Notebook
Video display Video only at 25% and 75% is none usable.
Posted by Gunz43 on
ravi chavan
    Champion:
  • 238 Answers
Ur question is not clear.. pls be specific..
Posted on Jan 05, 2008
Can a Nintendo 3DS Prepaid Card - $20 - usable on a Nintendo 2DS system ?
Yes, the systems are the same minus the fact that the 2DS cannot display the 3D images that the 3DS can. They both use the same Nintendo shop system.
Jul 25, 2014 | Nintendo 3DS Prepaid Card - $20 - Video...
I cannot get any sound through my tv from my acer ao531 notebook i have a picture but no sound
Try these options
1. Click on sound icon in Taskbar and make sure sound is up on HDMI volume. If this doesn't exist-
2. Start => Control Panel => Hardware and Sound. Under Sound tab click on Manage Audio Devices, right click on HDMI tab and enable. Or this: Computers have two seperate systems - one for video and one for sound.
The only computer (or laptop) connection that carries both video and sound is HDMI. If you do not have a HDMI/DVI connector on the back of your computer, then you will have to use the VGA-composite or s-video connectors to display your PC's output on an external monitor like an LCD TV.
On both my HP and Dell laptops the display settings (Start/Control Panel/Personalize/Display Settings) allow two modes - single or dual monitor mode. Single monitor mode allows me to switch between any one of three possible video outputs - VGA-composite, S-Video or laptop screen, or a split-desktop (display spread over two seperate monitors). Dual monitor mode allows the same display on any two of three possible video outputs.
Switching is performed using the fn keys on the keyboard (fn key plus the F2, F8, etc. function key with the display marking). You guys use single monitor mode until you figure out what your are doing. Select VGA-composite or S-Video.
Non-HDMI sound to your TV monitor or sound system must be obtained from your laptop's Headphone or S/PDIF jacks. Headphone is stereo and S/PDIF is 5.1 surround sound. Headphone is electrical, but S/PDIF may be electrical or optical (laser light). You must set the sound jack that you intend to use as the default on the PC control panel (Start/Control Panel/Sound).
None of these connectors is two-way in the context of an LCD monitor - your PC cannot record a TV picture or sound from the external monitor. To accomplish this you must purchase a video converter box that converts cable TV or video+sound inputs to USB format usable by your laptop. Do this and you can turn your laptop into a Tivo recorder/DVD burner using Beyond TV, Sage TV or a variety of other software packages.
Mar 10, 2011 | Computers & Internet
How can i increase my pc speed, i m unable to download and do many work at one time because my pc is very slow.
Try upgrading your Ram i recommend 2gb ram for pc in 3.0 ghz, 1gb ram for this kind of speed looks slower. they for efficient usability upgrade your Video card to handle heavy graphics. or if your not into upgrading your VGA try to disable you background set it to "None" and your Appearance to Windows Classic Style" you can see this feature in your screen properties
Feb 02, 2011 | Computers & Internet
Cant get any sound on tv
On both my HP and Dell laptops the display settings (Start/Control Panel/Personalize/Display Settings) allow two modes - single or dual monitor mode. Single monitor mode allows me to switch between any one of three possible video outputs - VGA-composite, S-Video or laptop screen, or a split-desktop (display spread over two separate monitors). Dual monitor mode allows the same display on any two of three possible video outputs.
None of these connectors is two-way in the context of an LCD monitor - your PC cannot record a TV picture or sound from the external monitor. To accomplish this you must purchase a video converter box that converts cable TV or video + sound inputs to USB format usable by your laptop. Do this and you can turn your laptop into a Tivo recorder/DVD burner using Beyond TV, Sage TV or a variety of other software packages.
Please let me know if you have any further questions or concerns.
Thanks.
May 07, 2010 | HP Compaq Presario C700T
Display screen flashes "CHK" repeatedly
Hello.
From FixYa Support: The "ERR" message reportedly means a memory error.
Please NOTE: This solution will wipe out the memory.
Press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again.
Hope this helps.
Apr 03, 2010 | Olympus VN-3100PC Digital Voice Recorder
When i connect my laptop to the tv i get sound but no pic.
Feb 11, 2010 | Dell Studio 1537 Laptop
Dell monitor model e152fpc error code "can not display this video mode"
Either the monitor or your video card may have been wounded or Windows has simply trashed the driver - it likes to do that, otherwise it would just get too boring, right?
You should try another monitor to see if Win likes it better. If you get a usable display, your monitor is likely at fault and not responding to the sync signals supplied by the video section. If you get the same error code on another monitor, then your video section is ailing and if it is an on board chipset, you may have to replace that failed section with a discrete card and disable the on board section through the BIOS setup. Good luck-
Sep 26, 2009 | Computers & Internet
No picture in small screen
Either means your video card is not usable with this device or could be just a problem with the driver you have installed for your display adapter. I would recommend going to the website of the manufacturer, and doanloading the latest drivers for this product.
Hope this helps
Sep 25, 2009 | Pinnacle Dazzle DVD Recorder
Trying to record and display says Eject cassette
May be a stupid suggestion but check the slide lock on the cartridge to make sure it is in the record position.
'Night vision' is a term applied too loosely; it originally referred to the original 'starlight' scope that uses a special tube capable of actually amplifying light particles (photons).  More recently, the phrase has been applied to devices capable of 'seeing' into the infra-red spectrum. Since too much IR sensitivity affects the quality of any digital camera, the sensors are normally designed to be less sensitive to that wavelength.
The fact that none of the specifications mentions the minimum usable light level is bothersome. Most digital cameras (and camcorders) have 2-3 lux ratings which is not in the category of 'night vision' at all.
Feb 22, 2009 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Need Manual
Display Optical Viewfinder Yes Optical VF Type Optical LCD Viewfinder Yes LCD Size (inches) 1.5 Power Battery Form Factor 2 x AA or 1 x CR-V3 Usable Battery Types Alk. / Lithium disposable, NiMH rechargeable Batteries Included 2 x AA Alkaline disposable Battery Charger Included No Flash Internal Flash Yes No of Flash Modes 4 Flash Modes Automatic, Fill (On), Off, Red-eye reduction Flash Range Description Unknown Ext Flash No Connectivity Video Out Yes Video Mode Switchable Yes External Connections USB 1.1 Other Connection DC In Included Software Unknown OS Compatibility Windows, MacOS Image Storage Usable Memory Types SD/MMC Other Memory Types Built In (8MB) Memory Included (MB) 8.0 Uncompressed Format None CCD Raw Format No Compressed Format JPEG (EXIF 2.1) Movie File Format MotionJPEG (AVI) Image Capture Image Resolution 1280x1024, 640x480 Movie Resolution 320x240 Aspect Ratio 4:3 CCD Sensor (Megapixels) 1.30 CCD Manufacturer Unknown CMOS Movie Audio No Quality Levels 3 Lens Digital Zoom Yes Digital Zoom Values 2x Auto Focus No Manual Focus No Normal Focus Range 120 cm to Infinity
49.0 in to Infinity Max Aperture f/3.0 Aperture Range Description f/3.0 Lens Thread Type None Exposure Number of White Balance Settings 5 White Balance Settings Auto, Sun, Shade, Fluorescent, Tungsten Manual White Balance No Longest Shutter Time 1/20 Shortest Shutter Time 1/2500 Exp Adj Range 1.5 EV Exp Adj Step Size 0.30 EV Metering Modes Auto Spot Metering No Aperture Priority No Shutter Priority No Full Manual Exposure No Self Timer 10 seconds General Model Number 3315 Camera Format Compact Currently Manufactured No Retail Price $99.00 Street Price $105.00 Price Update Date 2003-10-07 Date Available 2002-07-22 Remote Control No Tripod Mount Material Unknown Operating System Windows, MacOS Weight 120 g
4.2 oz Weight With Batteries? No Size 108 x 59 x 36 mm
4.3 x 2.3 x 1.4 in Warranty in Months 12
Oct 26, 2008 | Vivitar ViviCam 35 Digital Camera
IBM ThinkPad T43 Notebook Logo
Top IBM Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
