Press and holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, you can try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to make the Kindle Fire work again.Oct. 11, 2014
May 26, 2020 - Perform a soft reset. A soft reset resolves many common issues without affecting any data on the device. Press and hold the Power button for 40 seconds, then release. The charge indicator light should turn on after several seconds, and then the Kindle Fire should reboot.
Fix an Amazon Fire that Won't Start. Hold Power Button. Ensure that you are holding down the "Power" button for at least 5 seconds to power it on normally. Charge Using AC Adapter. Ensure that the Amazon Fire has a charged battery. Hold "Volume Down" While Powering On. Restore Latest Software.
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
However, sometimes when it locks up you can't tell because the screen goes dark, either ... it's already on but is locked up and thus won't charge or work properly. ... 15 minutes to make sure it gets enough charge, and then try turning it on again. ... If this tip (or anything else on my site) helps solve your Kindle Fire problem ...
Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
If you use the charger that came with your kindle fire, you can rest knowing that it will not overcharge by leaving it plugged in too long. Usually 4 to 6 hours should fully charge it though.
