Question about Pioneer AVH-X5700BHS 7& Double-DIN DVD Receiver with Motorized Display
Pioneer avh-x5700bhs motorized screen won't flip
The eject button lights up but doesn't respond to touch. The screen angle indicators don't light up. I'm not sure if the gears are stuck. Thanks
Posted by Amy Roberts on
5 Related Answers
Anonymous
  • 64 Answers
SOURCE: avh-p5700dvd touch screen
Go to: http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF This manual will give you everything you need for your Pioneer unit.
Posted on Nov 25, 2008
Anonymous
  • 64 Answers
SOURCE: pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at http://www.modifiedlife.com/1987-chevrolet-monte-carlo-car-audio-wiring-schematic/ You can refer to the installation manual for your deck at http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
Anonymous
  • 64 Answers
SOURCE: Pioneer AVH P6500DVD/AVIC 80DVD Installed.Pink Purple Green Wire?
can you take the black cage off or maybe you can take a screw driver and bend it back up
Hope this helps
install manual
owners manual
Posted on Feb 19, 2009
Scott Wright
  • 41 Answers
SOURCE: pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Posted on Mar 30, 2009
Anonymous
  • 253 Answers
SOURCE: how to unlock the eject button on a pioneer avh-p4000dvd
remove ur eject option from menu bar and for tchnician help contact http://tinyurl.com/mtgjzz
Posted on Jun 22, 2009
This unit motorhome with a avhx2700 radio unit. we have a very distorted navigation screen got any suggestions
[PDF]AVIC-U260 - Pioneer
https://www.pioneerelectronics.com/.../AVIC-U260+O... Pioneer CorporationPIONEER AVIC-U260 - for Canada 8. - END USER .... ing or distortion and, most importantly, with- ...... After a short pause, the navigation screen ap- pears.
AVH-X5700BHS - DVD Receiver with 7" Motorized ... - Pioneer
www.pioneerelectronics.com/.../AVH-X5700BHS
Pioneer CorporationFeb 16, 2015 - For more information, visit pioneerelectronics.com/AppRadioOne ....Easily upgrade to navigation with the addition of the AVIC-U260 add-on ...
GPS Navigation ' Pioneer Electronics USA
www.pioneerelectronics.com/PUSA/.../GPS-Navigati...
Pioneer CorporationCar Navigation Systems products with built in bluetooth handsfree technology. Includes dvd gps navigation: in-dash and portable. ... AVIC FEEDS App.
Jan 13, 2016 | Pioneer AVIC-U260 Add-on Navigation Unit...
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
Calibrating touch screen
calibrating touch screenProblem with Pioneer AVH-P5750DVD Car DVD Player
May 20, 2010 | Pioneer AVH-P5700DVD Car DVD Player
AVH-P5700DVD Car DVD Player: how to re-calibrate the touch screen for a Pioneer...
In order to calibrate the AHV-P5700DVD you need to press and hold the Boost and the + button and then press the reset button with a pen. continue to hold the Boost and + until the screen opens back up and you can see the calibration screen. use the arrow nob on the right to select the menu item, and the A button to select your item.
May 17, 2010 | Pioneer AVH-P5700DVD Car DVD Player
AVH-P5000DVD Pioneer eject lock ???? I can`t get CD out Thank you in advance
TURN THE UNIT OFF SO THAT ITS IN DEMO MODE OR SHOWS A BLANK SCREEN. THAT PRESS AND HOLD THE EJECT BUTTON AND MUTE/VOLUME BUTTON AT THE SAME TIME. THIS SHOULD TAKE THE EJECT LOCK OFF....
Feb 22, 2010 | Pioneer AVH-P5000DVD Car DVD Player
Flip up screen won,t illuminate. dark
if the screen needs to be wired to the dash light switch it will not change unless the lights are on, if the wire is disconnected it is possible to bypass it making the screen stay bright.
although it would seem more likely that the brightness could be adjusted on the unit settings or by a button on the unit itself
Nov 10, 2009 | Pioneer AVH-P5700DVD Car DVD Player
How to unlock the eject button on a pioneer avh-p4000dvd
Jun 22, 2009 | Pioneer AVH-P4000DVD Monitor
Eject lock pioneer avh-p5000
Turn it off so you see the "demo" screen or the blank "off" screen, then hold eject + volume (mute) button down for few seconds to turn the eject lock off.
Sep 29, 2008 | Car Audio & Video
Pioneer AVH-X5700BHS 7& Double-DIN DVD Receiver with Motorized Display Logo
207 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
