Question about Water Heaters
My heater doesn't turn on just a red light. How do I fix it? Is there a reset button?
Posted by Johnnie Gusby on
Don Walper
  • 36 Answers
There should be a reset button for each element...pull out some of the insulation under the inspection panels....with the power off of course.
Posted on Jan 13, 2017
My Bradford White Defender M-I-30T6FBN doesn't show igniter button on instructions
1) Copy following links to identify gas control valve and read ignition procedure, and access service manual for your product:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Honeywell gas control used on recent Bradford White gas water heaters has red knob that rotates to pilot. Press and hold red knob. Then push red igniter button until status light changes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 11, 2013 | Bradford White Bradford MI30T6FBN-337 30...
Please help!! I can't find the reset button on my Rheem 81V52D C model water tank! I opened the top panel and didn't see a red reset button. Totally confused now. Please help?
if there is no reset button, you should be able to turn the breaker off for a few minutes. then turn it back on. if its an electric water heater! it should reset it. good-day !
Mar 26, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
We purchased a new electric hot water heater we installed it on a 220 line and we are not getting no hot water
check with a vom set on high voltage setting. for power... black wire to black wire,, white wire to red wire on heater ground wire to tank ..on 220v there is no neutral like on 110volts..check red reset button under top panel / control push on it resets it,,,
Apr 17, 2011 | Whirlpool Water Heaters
I have no hot water in my home i can not locate the reset button
The reset button is located on the top thermostat, on the heater you will see a acess panel with screws in it to remove the thermostat and element is behind this panel. Once removed the top thermostat should have a red button to press to reset heater.
If it resets then wait for a little time for hot water. If this doesn't work then it could be the elements are in need of changing.
Apr 09, 2011 | General Electric GE SmartWater Household...
I own a Bradford White Corp. Electric Hot Water Heater. It has two thermostats, one upper and one lower. Model # M-1-40S6DS 13, ser# XK0300351. My problem is the red button on the upper control trips...
Hello. If you turn off the power and drain the tank then examine each of the heating elements you will find that the upper element is deteriorated. The fix is to replace the heating element. Actually though my practice is when one is bad the other isn't far behind so for a few dollars I change both when I have the tank drained. Joe
Feb 28, 2010 | Water Heaters
How do i use the reset button to turn the hot water to star heating again?
turn the dial to pilot and push and hold down red button while you light the pilot located inside water heater beside burner, keep holding button down after pilot is lit for about 1 minute. If you let go and pilot goes out repeat above steps and make sure pilot flame is heating up the thermal couple. If that fails replace themal couple.
Oct 24, 2009 | Rheem Water Heaters
Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Jan 21, 2009 | Water Heaters
Water Heaters Logo
60 people viewed this question
Top Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Water Heater Expert? Answer questions, earn points and help others
