These are not user serviceable. Return it to Dremel, a Dremel service center in tyour area, or if it was recently purchased to the seller and request an exchange.
I had a similar problem. I was going to take the charger apart but I ran into triangular socket head screws so in desperation I gently bent the 5 contact wires out from the battery socket. After slipping in the battery and plugging the charger into the wall socket, the charging light returned. The charger contacts that come into contact with the battery are easily pushed back and after a few battery insertions fail to make contact with the battery.
you might think im crazy but I just did this and it works so far anyway, I cut open my charger for my dremel 7300 model ,my green charging light stop working aswell , I felt naked without my dremel, so after the fourth day I cut it open and tinkered with it, I unwrapped some of that blue tape that\'s covering the copper spool , forgive my terms I don\'t know the correct name anyway I found a lil clear device connecting two silver wires, I twisted them together by grabbing the clear thing and twist until wires are connected put back together , put a batt in and green light came on and is charging, my charger looks like frankenstien but it works, how long will it last NO IDEA but if it stops ill post it, if you try this I hope it works, I should have videoed myself maybe nextime
try pitting battery in charge and wiggle the battery a little to see if the green light comes on, sometimes the make contact and then loose it when you let go of the battery.if still same problem charger is probbly dead.
