Question about Home
My pendolum wall clock chimes once on the half hour which is right. but also only chimes once on the hour.what do I do to fix this?
Posted by kvcblazer on
Questions Answerer
    New Friend:
Https://www.youtube.com/watch?v=5sPhIHScRDU
Posted on Jan 13, 2017
Bill Boyd
    Top Expert:
  • Home Master
  • 53,816 Answers
There is something missing in the gear mechanism of the clock and it is not chiming at all on the hour but on another 1/2 hour
take it to a watchmaker or clock repairer to have it fixed
Our clock chimes 3 hours ahead, if it is 7 o'clock, it chimes 10 times. we have tried all the fixes in the owners manual and nothing is working.
With our old clock when the chimes got off, we would advance the clock hands 3 hours while NOT allowing the clock to chime any of the hours or half-hours.
Jul 17, 2017 | Home
Wall clock Ptrausboury Manor chimes on half hour instead of hour. How do I fix it?
Try to carefully remove the MINUTE hand (not the hour hand, as posted previously!) entirely from the clock then put it back in the "proper" place. for example, when it strikes at the six, remove the minute hand and put it back on pointing at the 12. Then re-set the time for half-past (or maybe quarter-till the hour by now! lol)
Mar 29, 2017 | Home
After spot cleaning mantle clock with German movement (circa 1960), the clock chimes properly on the hour but does not chime on the half hour.
I am hoping that you oiled it also? One trick I have found is to gently lift the hammers and release, sometimes the hammers will release and strike the chimes/gong. Do this 4-5 times and hopefully it will get it chiming for you again.
UsedClockParts.com
Nov 09, 2016 | Home
The clock chimes right on the hour and used to chime once on the half. Now it chimes the number on the half instead of once.Need just chime once on the half
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Feb 26, 2016 | Home
I inherited a Seiko Westminster chime clock. The time is perfect but the hourly chimes are 3 hours behind. How can I synchronize the two?
Sep 21, 2015 | Seiko Mantel Clock
My regulator wall clock is not running right.the minute hand is chiming on the hour and the hour is chiming on the half hour.
Remove the dial nut and switch the hands so that they are correct and replace the dial nut.
UsedClockParts.com
Jun 25, 2015 | Home
My clock chimes on the half hour and counts on the hour. It chimes 2 minutes late on each. How to I get the chime on the half hour and hour?
Get it to chime then loosen minute hand then move hand back to the 12 or 6 position tighten minute hand and test to see if that works
May 08, 2015 | Watches
My clock chimes out of secrence quarter past then hour chime is quarter to hour? how can i fix please
Sounds like the minute hand is a quarter hour off. Make the clock strike on an hour. Count the number of times it strikes, then remove the minute (long) hand, and the hour hand. Replace the hour (short) hand to the number that the clock struck, and tighten by pressing hour hand in toward the dial, then replace the minute hand in the position that it's pointing at the twelve. Now it should be showing the time that it struck. To make sure, advance the minute hand to the half hour, and let it strike the half. Advance it to the next hour, and it should strike the correct time that is showing on the clock. For example, if the clock strikes four, and is showing three, then move the hour hand to the four while the minute hand is pointed at the twelve, then press the hour hand on each side of the center shaft towards the dial to tighten it. Now advance to half hour, and let strike, then advance to the next hour. It should strike the correct hour. I hope this helps more than confuses. Good Luck
Feb 08, 2015 | Home
Our wall clock was not wound a couple of months ago (it is a chime clock that chimes on the hour and half hour with weights) and when we rewound it, everything works fine except that the chime is out of...
You were not very specific about you clock description, Many of the German clocks were using auto correct features.
You may not have this function.
Move the hour hand to the correct hour.
Hope this tip help you.
R/
David
http://antiqueclock.clockstop.com/
Mar 13, 2010 | Watches
A few days ago the minute hand came off my HM Regulator keywind clock. I put the hand back on and the clock is keeping time, but the chime is not in sync with the time; re: it strikes the hour on the half...
yes
the positon of minute hand not sync with chime strikes.
you fix the minute hand as 15.minute slower and adjust the current time using time adjuster switch not with minute hand ok.
try it and solve it
Jun 19, 2008 | SkyScan 86709 Atomic Wall Clock
Home Logo
82 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
