SOURCE: LX 500 Keyboard not working mouse fine
Normal
0
Assuming that you have good batteries installed, turn the
Keyboard over and locate the small reset/connect button on the back of the
keyboard and press it. Then try to see if it is working. If not try
pressing the button on the receiver and then on the keyboard.
Turn the mouse over and find the small rest/connect button
on the bottom of the mouse and press it. This should connect the mouse to
the receiver and work properly. If not, try pressing the receiver button
and then press the button on the mouse. This should be done whenever you
change batteries or glitch.
Hope this
helps. Bud
SOURCE: Targus mouse not recognized
What is the OS of your computer? This Targus mouse would work with Win 98, Win 2000 and Win XP. Vista was not mentioned. And if you are running Windows Vista for you laptop, then that could be the reason why it was not recognized by the computer.
Is this the wireless optical mouse? If yes, you need to follow the steps below to isolate the problem:
1. Connect the USB receiver into different USB ports of the computer.
2. Replace the batteries with the fresh ones.
3. Try connecting the mouse into different computer to see if you've got a defective mouse.
If you've tried everything and got the same problem, you may need to refer to the manufacturer, because I'm not sure if this mouse is a Plug-n-Play device or if it needs a driver.
Have a great day!
SOURCE: My Targus PAWM10U wireless mouse doesn't work with Vista Ultimate
u need to sync it with your laptop
SOURCE: Pair new mouse/keyboard with built-in wireless rf receiver?
no, unless they are built by sony and listed as compatible.
