Question about DISH Network Televison & Video
Program dish network remote to my digital stream converter box
Posted by frank flores on
Electro Med Services
  • DISH Network Master
  • 6,694 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Posted on Jan 12, 2017
Ineed a code for tv converter box,What would the code be for a tv converter box ?
Different brand converter box will have differen tset-up codes. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Jan 11, 2017 | Televison & Video
I need code for digital stream box for a trinatron tv
Faq - digital stream technology, Inc. ( digital stream ...
www.dsconverter.com/index.php?p=5
Can I use my Universal Remote Control to operate the converter box? ... Do I need a special antenna to receive digital or high-definition TV? .... Note: If you want to reset the remote back to the beginning of the TV code list, clear the memory by ...
Installation - digital stream technology, Inc. ( digital stream ...
dsconverter.com/index.php?p=3
Connecting the DTV Converter Box to your Analog TV Set with RF cable · - Connecting the DTV Converter Box to your Analog TV Set with Audio/Video cable
Digital Stream Analog Pass-through DTV Converter Box
www.amazon.com/Digital-Stream.../B001TO3L8Y
Amazon.com, Inc.
Rating: 3.4 - ‎131 reviews
Digital Stream Converter Box Remote DTX9950 ... RCA DTA-800B1 Digital To Analog Pass-through TV Converter Box ... I think the bad capacitor is something like a 16 Volt capacitor, and you have to replace it with a ... remote(I was able to find the code for my old JC Penny TV), a seperate button for channel signal strength, ...
Amazon.com: Customer Reviews: Digital Stream Analog ...
Amazon.com, Inc.Digital Stream Analog Pass-through DTV Converter Box ... the code for my old JC Penny TV), a seperate button for channel signal strength, ... My brother somehow found out that there have been many of these Digital Stream boxes that were .... button that you can program into your tv (mine is a 1990's 11" Sony Trinitron).
Jan 14, 2016 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Program digital stream converter box without remote control
you definately do need a remote being a programmed universal one or just the one that comes with the converter box..either way theres no way of programming it..sorry learned it the hard way..good luck and by the way..make sure that you check that the remote youll be getting was made after 2009 and or thatll be compatible with a digital converter...
Feb 28, 2012 | Televison & Video
I want to program my Magnavox TB110MW9DTV Digital analog converter box to the aux button on my Dish network 4.0 IR/UHF PRO remote. I can't find a code to program this. I have talked with Dish and I have...
Hey there, Cheri Torres with DISH Network Customer Service here. We unfortunately do not have any codes for our DISH network remote controls that will program a Magnavox digital converter box. An option you can try is a power scan which will basically find the code for you in some cases. I will list here for you the instructions for addressing your DISH remote to your converter box. I hope you find these instructions helpful and if you have any other questions feel free to post back here and I would be happy to help.
Instructions for performing a power scan
  1. With the desired equipment on, press and hold the AUX Mode button until all mode button back lights illuminate, then release.
  2. Press and release the # 2 then the STAR (*) button.
  3. Press and release the Power button.
  4. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
  5. Press the POUND (#) button as soon as the desired equipment powers off. Note: If the code entered is valid for the remote, the mode light flashes three times.
Apr 09, 2011 | DISH Network IR Remote Control
How to i program a direct tv remote to my digital tv converter. dt250 model apex
nucklebuster
I have provided a link with instructions on how to program yoru remote to your TV. The Webpage also has links for the codes. I hope this helps.
http://2getdtv.com/directv/remote_codes.html
Ray Calo
DISH Network
Mar 23, 2011 | DISH Network IR Remote Control
Have to manually turn on tv when turning on digital converter box
astoner3,
Our dish remotes are compatible with most TV manufacturers. On some older TV, we may not have codes that allow for full functionality for the DISH remote. I have provided the most common codes to work with the Sharp TV. The codes are: 628, 605, 740, 591, and 606. I have also provided instructions on programming the remote to the TV.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
May 15, 2010 | DISH Network EZ Remote Remote Control
Can I program my dish network remote for a rca
Try the RCA codes listed in the code book that came with your Dish remote. You will want to use the "AUX" button at the top of the dish remote. You will likely NOT get full functionality if it works at all, however, there is a chance you'll be able to change the channels and power the converter box on and off.
If the codes you have are segregated into categories of different devices, i.e. TVs, DVD players, etc. You probably will not be successful.
Also, there should be instructions in the remote manual that will tell you how to search all codes that are stored in the Dish remote.
While this may not solve your problem, I hope I've given you helpful information that will allow you to make an informed decision as to where to go from here.
Let me know if I can be of further assistance.
May 18, 2009 | Televison & Video
Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
Apr 21, 2009 | GE JASRM24912 Remote Control
Televison & Video Logo
447 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
