If your LG classic flip phone is not able to call out or send text messages, there could be several reasons for this issue. Some of the common causes are:
Network Coverage: If you have recently switched to a different carrier, it is possible that your phone is not receiving adequate network coverage in your current location. Try to find a location with better signal strength.
APN Settings: It is possible that the Access Point Name (APN) settings on your phone are incorrect for the new carrier. Contact your carrier to obtain the correct APN settings and update them on your phone.
Phone Settings: Some phone settings, such as the network mode, may have changed during the switch to the new carrier. Verify that the settings on your phone are configured correctly for the new carrier.
SIM Card: The SIM card may have become damaged or is not compatible with the new carrier's network. Try inserting a new SIM card from the new carrier.
If none of these solutions resolve the issue, it is recommended that you contact the new carrier for further assistance. They will be able to diagnose the issue and provide a resolution.
You will need to contact the cell phone service provider you have used for service for your flip phone (which no longer has a SIM card) and ask your question.
just copy your contacts or move your contacts from your phone memory to sim card memory from Contacts setting menu. and paste it on any other IOS or android drive and import contacts. then again put your sim card in flip phone and first empty the sim card memory and repeat the same procedure;
Plug the charging cable into your laptop USB connection set the phone to usb and plug it into the cable, you should be able to browse the files on the phone and get the photos.
I know that they charge for this (it's only like ten bucks) but the verizon store has a machine that will move all info from one phone to another or to USB/SIM card regardless of the carrier. Go there and you'll be ok : )
Whats your exact LG flip phone model? You can unlock it easily by using an unlock code.You can get this code at reasonable cost from OnlineGSMunlock.com with easy step by step unlocking instructions and unlock it.Then you can use freely any GSM network Sim card.This is the fast and permanent unlocking method.
All mobiles have a sim card and are normally located under the battery.
Take the back of your phone, remove the battery and it should be there. Sim cards are normally a small oblong piece of plastic with a corner cut off. The flip side of one will have a metal strip, which is your sim memory. Don't damamge this side of the sim otherwise your card will be useless.
