Question about Xerox Office Equipment & Supplies
Reset admin password - Xerox WorkCentre 5335 - Xerox Office Equipment & Supplies
Posted by nesrine on
bitey
    Habit-Forming:
  • 125 Answers
Try:
  1. Press the Machine Status button, then Tools tab.
  2. Select the General feature, then Feature Installation.
  3. Enter the Feature Key on the Feature Key screen to reset the Administrator credentials to the default values ( admin and 1111).
Posted on Feb 06, 2019
5 Related Answers
Rick Kasper
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
Anonymous
SOURCE: how to reset a forgotten
PRESS # AND ACCSES SIMULTANIUS FOR 3 SECONDS
PASSWORD 1934
Posted on Oct 18, 2008
Rick Kasper
  • 2072 Answers
SOURCE: I bought Xerox Workcenter Pro 123 a year ago. One month later had a stroke and cannot remeber admin user ID or password. How can I reset?
Go to Xerox.com. Click on the Support and driver section.
Type in 123 in the search box. Then when it comes up, select Drivers and Downloads, then on that site you can click on Documentation and download the User and Admin Guides. That way you can have that info at your fingertip.
The default code is 1111, or 11111. 4 or 5 ones.
Posted on May 04, 2009
Anonymous
  • 24 Answers
SOURCE: I have Xerox workcentre pro 128 copier machine and
Service will have to come reset it. If you changed it from the default of login: 11111 and password of x-admin
Posted on Oct 25, 2009
SOURCE: Default admin password for Xerox Phaser 8550DX
Default admin password is 1111
Posted on May 03, 2010
Hello guys..please help me my printer xerox workcentre 7232 and i forgot my administrator password,how to recover my password or how to open it,tnx
you have to go into service mode to reset admin password
1) go to copy and hold zero for 7seconds and hit start while holding
2)password input which is 6789 ok now ur in tech mode
3)go to settings security change admin password
Aug 08, 2017 | Xerox Office Equipment & Supplies
What is error 027-502?
Appears to be error message related to networking.
26171215-uilodj0wn3aoics0ffhdkown-5-0.png see page 412 of 454 in the attached manual Xerox WorkCentre 5230A System Administration Manual Page 412
Apr 21, 2016 | Xerox WorkCentre 5325 5330 5335 Black...
Error code 116-330 xerox workcentre 5325
4+power saver button+stop button press&hold then machin on disply hard disk formet then machin off& on Now ready your machin
Jan 10, 2016 | Xerox Workcentre 5325/c 5325 Black & White...
How to reset fuser xerox53xx
try here and put your model number in
http://www.support.xerox.com/support/enus.html
Jun 12, 2014 | Xerox WorkCentre 5325 5330 5335 Black...
How do a forgotten admin password on a xerox 7655
WorkCentre 7655 7665 7675 Online Support Solution Modify the Printer...
Solution : Modify the Printer's Administrator Password Using CentreWare Internet Services (CWIS) NOTE: This solution assumes the WorkCentre is configured and working properly on the network.
  1. From the computer, open an Internet browser window.
  2. Enter the IP address for the WorkCentre in theAddressfield, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  3. Click on the [Properties] tab.
    NOTE:If the Login screen is displayed, enter the user name in theUser IDfield, and the password in thePasswordfield, and then click on the [Login] button.
    The default username is "admin" (case sensitive), and the default password is "1111". If it has been changed or forgotten, contact Support.
  4. Click on [Security] to expand the list of options.
  5. Select [Authentication Configuration].
  6. Click on the [Modify] button for Device System Administrator Password.
  7. Enter a new password in theNew Passwordfield.
  8. Retype the password in theRetype Passwordfield.
  9. Click on [Save]. This will be the new password to log into the Control Panel and CWIS.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=143,E=0000000004704152929,K=9646,Sxi=4,Case=obj(3814)
Solution : Modify the Default Admin (Tools Mode) Password on the WorkCentre NOTE:The Admin (Tools Mode) password allows access to configure network and machine settings on the printer.Xerox recommends only changing the default Admin (Tools Mode) password if absolutely necessary. If the password has been changed from the default password (1111) and has been forgotten, a service call is required to reset the password.
To change the default Admin (Tools Mode) password:
  1. Press the [Log In / Out] button on the Control Panel. The Log In window will be displayed. See theRelated Itemsbelow for additional information regarding logging into the WorkCentre.
  2. Select [Security Settings] on the left side of the screen.
  3. Select [Authentication] from theGroupscolumn and then select [User / Administrator Accounts] from theFeaturescolumn. The User Administrator screen will be displayed.
  4. Select the [Account #] field, and then select account number 1 using the keypad on the Control Panel.
  5. Select the [Configure Account] button. The Configure User Accounts screen will be displayed.
  6. Press the [Clear C] button (several times, as required) on the Control Panel to clear the old password.
  7. Enter the new password using the keypad on the Control Panel.
  8. If necessary, place a check mark in the [System Administrator (Admin)] and [Account Administrator] check boxes, and then select [Save Account].
  9. Select [Close].
  10. Press the [Log In / Out] button on the Control Panel.
  11. Select [Logout] on the Touch Screen.
Apr 04, 2014 | Xerox WorkCentre M-24 Color Copier
What is the default password for the Xerox workcentre 24?
It looks like the username and password are both 'admin', and if that doesn't work it might be '11111'.
I found the manual here, which might help for future problems: http://download.support.xerox.com/pub/docs/WCM24/userdocs/any-os/en/WCM24_Quick_Connect_Guide.pdf
Mar 03, 2011 | Xerox Workcentre M24 Color Copier
The machine's admin password has been lost/forgotten. Is there anyway I can reset the password?
it can be reset in diagnostics. Hold down the # button and hit the Access button. That pass code is 1934. Reseting the admin passcode for the tools menu is in there some where.
Sep 23, 2010 | Xerox WorkCentre 4150 Black and White...
How do I perform a factory reset on a Xerox device
lol m looking for the same thing if u have found the answer can you please post it here ?
Jan 18, 2010 | Xerox Office Equipment & Supplies
I have Xerox workcentre pro 128 copier machine and we don't know what the user name and password is. It was reset from default
Sep 02, 2009 | Xerox WorkCentre PRO 128 Copier
4,130 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
