I entered test mode and cannot exit. When I turn off machine after test, all I get is error E1 message. I am locked out... Is there a set of commands to exit Test Mode? Please help!!!
SOURCE: i can't sew on my machine
I had the same problem.There is a gold or silver washer on the back of the sewing machine that holds the part inside that you are connecting to. If the washer is gone or loose you will not get a connection when you insert the foot peddle. This peice inside is small and square with three delicate wires attached, You should be able to see it
SOURCE: I get an E6 message while trying to sew on my Brother cs-6000
Here is the online manual for your machine. http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000_ES_2000_EN_185.PDF
SOURCE: Error message on Brother SE-270D sewing machine
The safety device will activate if the machine has a bind or is unable to run at correct speed. If you turn the handwheel is it tight/hard to turn? if it is than thats it. Now what is binding the machine has to be diagnosed.
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
SOURCE: manual from brother listed sewing machine
I believe these are the UL code and serial number. If there is a display band of decorative stitches on the front of your machine look on the bottom right of that panel. If the number there is a VX-920 there is no manual available for it BUT you can use the manual from the VX 970 which IS available. Do a search for that model manual in Spanish and you should find one.
