SOURCE: JVC TH-A9
1st u need to covert stereo cable with stereo conversion pin which avelieible in electronic consumer store after u got this cable u able to connect ur speakers directly to play station or a tv
SOURCE: JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
SOURCE: jvc th-c6 subwoofer won't turn on
Check the little prongs inside of the cord, they are very fragile and if they get pushed in wrong, bent and broken off - you would never see one on the floor. These should all be straight and be able to make contact. Hope this helps!
SOURCE: Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
SOURCE: i have a JVC, Home Theater system. It is a TH-C30.
I think there may be a possible chord disconnected or the fuse may be bad!
No sound. The system cord and/or speaker cord is not connected. Check the connection.
The audio cord is not connected to AUDIO IN (VCR)
and/or DIGITAL IN (DBS) correctly.
Connect the cord correctly. (A pg. 13)
An incorrect source has been selected. Select the correct source. (Apg. 17)
The decode mode is not set correctly. Select the proper decode mode. (A pg. 35)
http://www.retrevo.com/support/JVC-TH-C5J-Home-Theater-Systems-manual/id/318ag518/t/2/
Do you think the powered subwoofer itself might have a power problem? Check its cord.
