Computers & Internet Logo
R
Ramprasadreddy Posted on Jan 10, 2017
Is the sd wifi card inserted in acer n30 pocket pc slot internet connection nwill work
2 Related Answers
Anonymous
  • 903 Answers
  • Posted on Sep 11, 2005
SOURCE: Pocket PC e400 en Sandisk WiFi
I have bought the Bluetooth Option Part for my e400. It was an "PC Bluetooth SD Card2". In the specs of the Bluetooth Card is an SD/IO enabled SD Slot required for the Card. So I think your Wifi will also work.
clark_styx
clark styx valencia
  • 282 Answers
  • Posted on Jul 05, 2008
SOURCE: Direct Internet Connection with Matsunichi i-mat IP3230 Pocket PC
if you are telling me that it has already builtin wifi,you dont have to buy it, those people who doesnt have built in wifi can use sd card for wifi,im sure it will fit to yours,because SD card has standard size..
Hi There, My Acer N30 has completly frozen, it has
Hi, I think is software issue get someone to re-install the operating system of your ACER and it should work well again
1helpful
1helpful
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
1helpful
Acer n30 wlan card
If your router has wireless broadcasting. Check all the settings in your router. Add the MAC address of the WIFI Card to your routers Wireless settings and also maybe in your firewall settings in the networking of your router. Be sure to add the WEP key when you connect to your router. Check your security settings.
1helpful
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Acer n30 problem with expansion slot.
The spring lock needs to be adjusted, you need to open it to make it work again. Although if you want to try a nifty trick I do with cards spitting out in the slot is to put a square-cut electrical tape on both sides of the sd card and it will stay in...
Acer N30
I can't believed it. Solution couldn't be more simple!
At Device Manager where it appears with exclamation mark, just click Update Driver and then choose Install the Software Automatically.
Windows can find it.
2answers
Ipaq 6515 & WLAN?
Buy a WLAN sdcard to get WiFi connectivity. You will still have the second minisd slot available for a memory card.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
