I never dropped it, my other games look fine and they read perfectly!
SOURCE: Nintendo DS LIte - game upload
GO onto your computer and insert the cd-rom, then access your ds system and switch the portals.
SOURCE: Nintendo DS lite won't play nintendo games!!!
You can't produce a code out of mid air............
SOURCE: nintendo DS not recognising R4DS CARD
Had this problem too. Solved it by cutting a small piece of thin card (cigerette box} or anything similar , and inserting it along with the r4 card to make it a tighter fit.Insert it in the back side of the r4 card, not the side with the metal contacts.hope this helps.
SOURCE: Nintendo DS Lite not reading some games
this is a problem with the pins inside could be dirty or dusty ether way you will need to get a cleaning fluid ie 100% alcohol cleaning fluid us a clean cotton bud inside the slot and use gently as not to damage pins, if the pins are heavy soiled you may need to get a fiberglass tipped pen wich is used to clean up poor contact areas on boards and other electrical circuits
hope this helps if unsure get in touch with nintendo they will prob fix it for you for free go here > http://www.nintendo.com/consumer/repair/
SOURCE: NINTENDO DOESN'T RECOGNISE GAMES IN SLOT
Clean the Ds slot. This happens to me alot, but I just blow into the slot and it works.
