Televison & Video Logo
Joyce Sloan Posted on Jan 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A vizio tv with fine horizontal lines in picture
Fine horizontal line are on whole screen.....if the color of picture is dark they barely show up....lighter colors they seem to show up more....this has been going on for over 2 years....once in awhile the picture will become a little distorted and it usually fixes it self....sometimes I have to turn tv offand then back on to fix distortion but the fine horizontal lines stay on screen could this be a bad led driver board? M3d550kd is model #
Marvin
Level 3:
Top Expert:
  • Vizio Master 85,242 Answers
  • Posted on Jan 10, 2017
Marvin
Vizio Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29057109
Points
266281
LG 65LS5700 horizontal lines fix?
The cable is either bad or the cable has not been securely full connected to the input and the output ports can have loose connections and can cause the signal and have horizontal or vertical lines to show up on the TVs screen. The cable will need replacement.
1helpful
Vizio TV has a horizontal 2mm black/multicolor line.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Only half rca tv screen shows up
I think you may have a tv tube problem...
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
1helpful
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
Picture Problem
In that set its usually a bad picture tube. The lines you are seeing are called retrace lines. You can take it to a shop and they may be able to rejuvenate the tube
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
1helpful
2answers
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
