Kitchen Appliances - Others Logo
chris harvey Posted on Jan 09, 2017
Where is the fuse located on New World Electric Cookers? Or isn't there one??..
My gourmet classic leisure cooker has a noisy fan. What can I do?
Hello CAROL ROSA,
If it is NEW... TAKE IT BACK.
ELSE... (replace the fan).
Post the actual model number to see if
we need to look for 'parts' (USA) or "spares" (rest of the world)...
Together we can get this
'FIXED' (USA) or "sorted" (rest of the world)...
http://www.harveynorman.ie/home-appliances/cooking-appliances/range-cookers/leisure-gourmet-classic-oven-grb6cvr.html
Where is the circuit breaker on a electric cooker
cookers usually use a thermal fuse close to the heating element fuses range from 150c to 190c.once you find the fuse check it with an ohmeter it should have continuty. the thermal value should be printed on the fuse.
How do I cook wings in a pressure cooker
Get online recipes for cooking all kind of meats and follow the instruction of manfatures
Always be careful with operating pressure cookers
4answers
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
AER5630BAS died
Check the fuse/ circuit breaker in the fuse box first if that's ok some electric cookers have a fuse or a fusible link inside the back panel, you will need a multimeter to test it (be careful electric cookers are dangerous to work on) if you are not familiar with them.
I have a Nesco electric 6 qt pressure cooker PC6=25 / Digital Pressure cooker, I went to use it, it worked for a while, then all at once everything turns off...nothing....I think it may have blew a fuse,...
A THERMAL FUSE IS LOCATED INSIDE THE COOKE BETWEEN TERMINAL AND ELEMENT(HEATING) IF YOUR HAVE ELECTRICAL KNOWLEDGE YOU CAN RECTIFY OR ELSE CONSULT PROPER TECHITIAN .
Top Electric Kitchen Appliances - Others Experts
NOEL
NOEL
vince
Are you an Electric Kitchen Appliances - Other Expert? Answer questions, earn points and help others
