SOURCE: Frigidaire oven heating elements **** the bed
open the bottom drawer and get the model number off the serial plate on the left hand side i think its a slide in with the controls on front
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
SOURCE: Hi my Fisher & Paykel Paprika stove (Model
Yes the regulators/simmerstats are stuffed but are not hard to replace...but please turn off the power 1st when removeing the backing plate as you will kill yourself....yes you will.
Use a multimeter set on volts ac or a volt detector stick, test tester on a known live sourse 1st like a power point....switched on
SOURCE: I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
