Televison & Video Logo
Question about Vizio Televison & Video
Vizio model d65u-d2 NO POWER How to troubleshoot power on problems
Posted by Allen Wishman on
Electro Med Services
  • Vizio Master
  • 6,694 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Jan 09, 2017
2helpful
Vizio D65u-d2 Backlight not working after replacing 2 LED strips?
You should be able to replace just the bad LED strips however with as much work as it is to get the set apart and back together I always replace all them as other strips generally fail in time. Did they all light up after you replaced the bad ones before you put it back together? This model set has local dimming so servicing it is a bit more complex, you could have a bad backlight driver but that board seldom gives issues, also you could have main or power board issues as power for the backlight driver comes from the power board or you could have main issues as it's the signal from there that turns on each strip.
2answers
Model d65u-d2. Why does it have a black screen?
only an educated guess back light is the problem , might be power supply of the led strips call a local repair shop
Hi, I have Vizio d65u d2 Screen goes black after 3 minutes, I change power board supply and led board, but still same problem
Hello
Make sure the connectors are snugly in place and that the set in not i a position that stress the boards, reset all settings then
change the picture mode to standard and auto brightness to medium
Good Luck
Mr.Mike
Top Vizio Televison & Video Experts
Marvin
Marvin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
