SOURCE: I am replacing the washer
Hello HmKm, You should be able to just pull the knobs straight off the control stems. Once you have them off, there are a couple of screws on the angled section just above the washer lid. Remove them and you will be able to access the washer controls.
Before you go working on the parts, to remove the control timer, please unplug the stacked washer/dryer combo and turn the water offl. Now you can remove the two screws (that are behind the timer knob) to free it from the metal control panel. Depending on your model, there might be another mounting strap inside the unit that holds the timer in place. If so, remove those screws and you shoud be able to drop the timer down and remove the wiring connection plugs and take out the faulty timer. Now simply push the wiring plugs onto the new timer and reinstall.
Close everything up, reversing the procedures above and turn the power back on and the water and you should be able to use the washer/dryer as normal.
Hope you find this Very Helpful and best regards!
PS: I was one of the folks that was trying to conect with your request for a live chat, but the system wasn't responding, so I aplogize for that technical glitch. Anyway, this is what I would have provided you during the chat session, so best of luck to you in undertaking the repairs.
SOURCE: Removing Timer Knob 417.29052990 Washer
I just ran into the same issue. Turns out the knob has a piece in front that easily pops off with a screwdriver or pocket knife. You can then pull the little washer thingy that holds it in place and the replacement becomes a no-brainer. Good luck!
SOURCE: Hi, Our Electrolux EWF1083 is not spinning and ...
Hello,E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
The drain pump may be blocke.check www.serviceforce.co.uk
Thanks
SOURCE: TRYING TO FIND AN ELECTROLUX EWF1083 MANUAL
You can download from here: http://www.electrolux-ui.com/2008/147/143581EN.pdf
SOURCE: My Electrolux Front Loader EWF1083 displays E20
E20 means problem draining.
Clean the drain pump filter and check the drain hose.
you can download a copy of the manual here:
