Cleaning light turns on frequently even after cleaning
I have cleaned my machine several times in the last 2 weeks and the cleaning light keeps coming back on. It can't possibly be that dirty. I use the vinegar and water solution and then rinse. What's up?
How long has it been since the last professional maintenance? Could very well be that it needs a good oiling and cleaning. Mechanical machines require frequent oiling to keep them operating. Overlockers probably require more frequent oiling than sewing machines because they sew so much faster that the moving parts dry out quickly. Even though you probably oil the basic external spots of the machine, there are multiple areas that are hidden under the case that need oiling as well.
It is sensing mineral deposits a.k.a. "scale". Run white vinegar thru the maker several times to break down and remove the scale. Flush several times with clean water before using to make coffee again.
WHAT SHOULDN'T BE DONE.
Never keep anything in the ice storage bin that is not ice; objects like wine or beer bottles are not only unsanitary, but the labels may slip off and plug up the drain. Never allow the machine to operate without regular. The machine will last longer if it is kept clean. Regular cleaning should happen at least once per year,and preferable twice. Some water conditions will dictate even more frequent cleaning of the ice making section, and some carpets or pets will dictate more frequent cleaning or the condenser.
WHAT SHOULD BE KEPT CLEAN?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
HOW TO CLEAN THE CABINET.
Wipe off any spills on the surface of the door and handle as they occur. If anything spilled on the door of gasket dries onto the surface, wash with soap and warm water to remove.
HOW TO CLEAN THE ICE STORAGE BIN.
The ice storage bin should be sanitized occasionally. It is usually convenient to sanitize the bin after the ice making system has been cleaned, and the storage bin empty. A sanitizing solution can be made of 1 ounce of household bleach and two gallons of hot (95 deg F.-115 deg F.)Water. Use a clean cloth and wipe down the interior of the ice storage bin with the sanitizing solution, pour some of the solution down the drain. Allow to dry.
HOW TO CLEAN THE CONDENSER.
The condenser is like a radiator on a car, it has fins and tubed that can become clogged. To clean:
1. Remove the kick plate.
2. Locate the condenser surface.
3. Vacuum the surface, remove all dust and lint.
4. Replace the kick plate.
CLEANING THE SYSTEM.
HOW TO CLEAN THE ICE MAKING SYSTEM.
1. Open the door and turn the ice machine control knob off.
2. Scoop out all of the ice, either discard it or save it in a ice chest or cooler.
3. Pour 4 ounces of Scotsman ice Machine Cleaner ( available from a local Scotsman Distributor or Dealer, ask for part number 19-0343-06- an 8 ounce bottle) into the ice machine reservoir.
4. Turn the ice machine control to ON.
5. Allow the machine to operate for about 2 hours.
6. Pour hot water into the bin to melt the ice that has formed. That ice will likely be white and frosty looking.
7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off of the liner.
8. Rinse the liner with hot water.
9. Sanitize the bin interior.
10. Replace the ice removed in step 2.
The ice scoop should be washed regularly, wash it just like any other food container.
WARNING; Scotsman ice machine cleaner contains acids. These compounds may cause burns. If swallowed,DO NOT induce vomiting. Give large amounts of water or milk. Call Physician immediately. In case of skin contact,flush with water. Keep out of the reach of children. Always follow manufactures directions.
We have this problem as well. We simply clean it as directed once or twice with the vinegar and water mix and then unplug for an hour. This resets our machine for several weeks. Based on the number of comments I've seen on this issue, it seems that the "off" sensor doesn't work.
It could be something more serious, but this problem is frequently due to
corroded battery contacts inside the camera. Remove the batteries and
wipe the camera contacts firmly with a clean cloth (heavy corrosion may
require cleaning with a fine wire brush, steel wool, or fine
sandpaper). Remove any residue that may have fallen into the battery
compartment during cleaning, clean the contacts at both ends of the
batteries, and reinsert them in the camera. This cleaning cures the
problem about 90% of the time, and I hope it works for you.
Is your needle new? The needle needs to be replaced every 8 hours on a regular sewing machine, and the ULT benefits from even more frequent changes. Also try a bigger needle, if you're using a 75/11 move to a 90/14, make sure your needle matches what you're doing, you might not think those little needle tips differ much but they really do.
The manual also mentions if there is to much lint under the needle plate. Keep in mind all sewing machines need the bobbin area cleaned out every time you change the bobbin, but the ULT likes cleaning up down there about twice as often.
Have experienced the same problem for the last nine months. Was finally able to solve it today by following this guide: http://www.wholelattelove.com/articles/jura_capresso_cleaning_guide.cfm
Having cleaned the shower screen I ran the regular cleaning cycle and now the display indiucates "Ready" as it should do.
